Old 10-30-2006, 07:42 PM   #1
Buckman
No dash lights or taillights and parking lights
This morning I went out to go to work and my 71 gmc had no dash lights or tail lights or parking lights. I check the fuse under the dash and it was ok. Where should I go to next?
Buckman is offline   Reply With Quote
Old 10-30-2006, 07:54 PM   #2
l79m20
Re: No dash lights or taillights and parking lights
May be a ground issue or maybe the headlight switch itself...........Joe
l79m20 is offline   Reply With Quote
Old 10-30-2006, 07:55 PM   #3
zden
all the power for these runs through the light switch. check the connections there.
1966 Chevrolet Suburban
1955 Chevrolet Bel Air
zden is offline   Reply With Quote
Old 10-30-2006, 08:04 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
brake lights don't go through the headlight switch.
Did you test that fuse, or just look at it? They can blow clear up at the end and you can't see it.
You defenatly have a power problem, those all run off that one fuse.
Old 10-30-2006, 08:30 PM   #5
Buckman
I check the fuse its ok, the headlights work fine.
Old 10-30-2006, 08:32 PM   #6
Longhorn Man
time to get the test light and find out where you stop getting power. I suspect it'll be close to the fuse box being that it branches out afterwards.
Old 10-30-2006, 11:51 PM   #7
timcos
Chief Honcho In Charge
timcos's Avatar
He said he had no tail lights (running lights I expect)...not brake lights. Parking lights being those side marker lights, or the front amber lights.
1992 1500 4x4 Shortbed
1984 Ford F250 Supercab Longbed 6.9L Diesel
1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
1967 C10 SWB (1980-1981)
1971 C10 LWB (1998-2004)
timcos is offline   Reply With Quote
Old 10-31-2006, 02:12 AM   #8
Jayman931
Jayman931's Avatar
Jayman931 is offline   Reply With Quote
Old 10-31-2006, 03:08 PM   #9
Longhorn Man
Buck, do your brake lights work?
Old 10-31-2006, 07:23 PM   #10
zden
since you say the headlights are working you must have power to the switch. i would bet there is a bad connection at the switch.
Old 11-01-2006, 09:05 AM   #11
Buckman
longhorn, I have no brake lights.
Old 11-01-2006, 03:57 PM   #12
Longhorn Man
OK, start at the fuse box, looking for power. remove the fuse, and make sure the holders are not corroded/rusted. You'll probably shatter the fuse removing it, so have glasses on, and have a spare fuse in your pocket.
I am 99% positive your problem is in that area since everything on that circuit is dead...and assumingly all at once.
Old 11-02-2006, 02:50 PM   #13
Buckman
Talking Re: No dash lights or taillights and parking lights
It was the fuse, I look at the wrong one the first day.
Tks guys.
