10-31-2006, 03:13 PM | #1 |
How to make it hook up????
I am contemplating swapping my current 350ci SB for a 468ci BB. What should I run in the 12Bolt? Can anyone recommend using a spool as opposed to limited slip differential? The LSD cost 3.5 times what I can get a spool for. Any thoughts????
Jesse
1985 SWB Silverado 1/2 Ton 1972 Chevy SWB 1/2 Ton (sold) 1972 Chevy Chevelle SS (sold) 1971 Chevy Nova (sold) 1967 Chevy El Camino (sold) 2001 Mustang Bullitt (sold) 2019 Toyota Tundra Crewmax (daily) |
10-31-2006, 03:16 PM | #2 |
Re: How to make it hook up???
i have a spool and love it
10-31-2006, 03:19 PM | #3 |
Re: How to make it hook up????
maybe read the rules about double posting
10-31-2006, 04:25 PM | #4 |
Next project: 1970 K10
If it's not a daily driver, I would go with a spool. But if it is a daily driver, plan on new tires more often. I used to run a spool in my 81 SWB, and went through tires like mad. Driving in town just torn them up with all the turning corners and such.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
10-31-2006, 04:25 PM | #5 |
I am a Referee of life.
Spool will hook better but is gonna be a pain on the street.The best way to get it to hook up is probably a 4 link.However the basic rear suspension in these trucks (Coil spring) is used in NASCAR.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
10-31-2006, 04:43 PM | #6 |
just run your twin i beam with rear coil overs. here are some pictures of what can be done with factory suspension. one is of truck the other is of the suspension in the truck notice factory i beams.
10-31-2006, 05:02 PM | #7 |
A GM 12 bolt posi with the upgrade clutches and springs will work. Believe me, I have twisted aftermarket axles with this setup and 14x31 slicks.
10-31-2006, 05:02 PM | #8 |
Its not a daily driver, but I drive quite heavily on the weekend. Prostreet what spool did you use? And does yours make that gawdawful popping sound that spools do? I had one in my 67 El Camino and it drove me nuts Jesse
10-31-2006, 06:02 PM | #9 |
i run a spool in mine and if you have popping noises coming from it something done broke, sure it wasnt a locker that popped, they will do that.
10-31-2006, 06:11 PM | #10 |
Probably was the suspension "popping", as it will kind of get twisted when cornering, but then something it has to give way, or "slip". My 81 SWB use to pop, but it was to springs/perches and stuff getting twisted then POP back into place then twist again......
10-31-2006, 06:16 PM | #11 |
I am running a 3.73 with a Lock-Rite locker. Love it.
10-31-2006, 06:27 PM | #12 |
With a spool, you are literally dragging a tire around every corner.
10-31-2006, 06:28 PM | #13 |
i have 350lbs of steel plate in the frame rails on my 85 it hooks real hard..
10-31-2006, 06:31 PM | #14 |
one more of the ladder bars and disc brakes
10-31-2006, 06:35 PM | #15 |
If you run a spool on the street get some cheap narrow tires to run. I had a spool in my daily driver for about 11 months. Drove from Edgewater MD into Capital Hill DC everyday.(0 miles round trip, parallel parking was a pain though
10-31-2006, 06:40 PM | #16 | |
Could I see a picture of that set up from the front and back?
The Fastor Pastor '68 swb, 447 BBC/ 6-71 Weiand, Dual 950 Bigs Carbs/ 2 1/2" Header tubes - 4" collectors/ M-21 4speed: '70 swb; TH-400 - bagged & shaved. Looking for new engine or parts. Wife - Original {A Real Classic!} |
10-31-2006, 06:42 PM | #17 |
mini truck racer
Why noy look into a drop in or lunch box locker like the 4x4 guys use? Just replace your side and spider gears and retain your current carrier and center pin . Should be a little more street friendly . A clutch type posi would be best IMO.
10-31-2006, 06:51 PM | #18 |
I ran a spool in my old 69 camaro. After breaking 2 axles making U turns I got rid of it. Too much hassle. You will end up spending more money on broken parts and tires than to get a good posi type unit.
10-31-2006, 10:12 PM | #19 |
Location: vacaville ca, because it as far from indy as i can be
you dont want a locker on a street truck, to irratic and jumpy, it wont launch as straight as you want for a pro street truck. either a spool or a posi but as said a spool is harsh for a dd nice truck, mean nasty street/strip racer its the ticket. posi is much much nicer and smoother but will give you a straighter launch and wont shoot you off at the wall. its much safer in ****y weather too, a spool can very easily get you wrecked.
i would run a spool but i was given a posi unit by a freind. my truck is also not and never will be any kind of show truck, just ugly and fast. |
10-31-2006, 10:26 PM | #20 |
I have a mini spool in my 68 , it's a pain on the street , it actually behaves better with the slicks on . I would watch Evilbay for a Eaton posi , i got one new for $200 plus the ride ( Not installed yet ).
Later .................................... 409
Can-Am Motorsports 37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser . 64 Biscayne 409 2x4 4 speed 4.11 posi 65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon) 68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD) |
10-31-2006, 10:53 PM | #21 |
mini truck racer
I bought an eaton posi off of ebay for $49 . The quirks that a locker has can be driven around on the streets , Coasting through corners squaring the truck off before accelerating .
11-01-2006, 07:52 AM | #22 |
Is this the best you could do? It takes time to reply, but not a second to just ignore the post if not interested in replying with some helpful. Thanks for the scolding anyway, Dad.
11-01-2006, 09:03 AM | #23 |
NCStroker
has anyone used the powertrax locking differential. was looking into putting it in my truck. any opinions.
heres the link to it on jegs. http://www.jegs.com/webapp/wcs/store...tegoryId=10153
1971 Chevy C/10-Built 383 Stroker |
11-01-2006, 09:05 AM | #24 | |
No No
The lock right is a cheap effective locker that will do the job and still allow you to turn with minimal wheel hop compared to a spool. Then you need to address weight transfer with your suspension to help keep force on the rear wheels.
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
11-01-2006, 06:42 PM | #25 |
Thanks, SSC!!
I ordered the Lock Right earlier today from JEGS. I will install it along with the 468 this weekend if the fellas are game! BUDWEISER works as a bribe. LOL Jesse
