The Hammer Man
![]() Join Date: Oct 2006
Old gas tank for speaker mount
Has anybody tried this? Someone mentioned it and it got me thinking, wow that could really work (i think) or someone should come up with a speaker box shaped like the old gas tank and oila a home based ready to order. Think about all the old gas tanks people are just willing to get rid of and then later you have to send your old one in to get a price cut on the new one all fabbed up with speakers of your choice. could work.
Boise69. Bought in Boise ID and its a '69 ___________________________________________ 1969 Chevy C-10 SWB 350/400 - drivable project www.americanhammer.com 2013 MBZ Sprinter customized 2005 MBZ Sprinter Van 2004 Land Rover Discovery 2001 Yamaha Road Star 1997 MBZ E420 1989 Ferrari Mondial T |
Re: Old gas tank for speaker mount
Only problem I see is that you'd be firing into the back of your seats unless you had buckets.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
not much of a sound guru but i think it would rattel like the tin can it is. not to mention take up more space that could be better used in my opinion
common sense isn't so common anymore |
The Hammer Man
lol yea but i dont really mean the can itself, but re-fabbed with sound insulation and mod in a way it wouldn't sound like a gas can. but i thought by posting that question someone would come forward with exactly that and it was actually done. When i take mine out i would trace the lines of the tank and make something to fit just like the tank.
![]() Join Date: Mar 2004
the only way it would work properly as a sound box is if it was rigid. there is also the anount of volume behind the speakers to contend with. in short the tank as is, is too flexable and far too large volume wise to get a good sounding system. you are much much better off making a box with the vloume you need out of MDF. it will work better and you will have room for extra stuff like the amp.
#6 | |
Freeeeee Mason...
![]() Join Date: Dec 2001
That's kind of what I did, needed a little bass in the rig and added 2 fairly shallow 10s in an MDF box covered in suede. I even used the gas tank mounting holes with longer bolts. Nice back massage after a long day.
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
Too many projects
You can also fit 12's back there, and they fire into the back of the buckets, but she still sounds great. Here's mine, made a box the exact width of the cab (never will take it out, if I could) out of 3/4 MDF, covered with carpet, and bolted a panel on top to steady the box and help thwart theft.
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
![]() Join Date: Feb 2012
I know this thread is Way old but am wondering if anyone has come up with any other ideas over the past few years. I am thinking about cutting an old tank in half lining the inside with sound deadener and bolting it back together.
#10 | |
The Older Generation
LockDoc
#11 | |
http://smg.photobucket.com/albums/v655/aaronhero/ |
Thanks for the Info.
#13 |
Active Member
![]() Join Date: Jul 2007
Many years ago I did some research about this subject. Even got a book about building speakers. They recommended a solid enclosure -preferably made out of 1/2"to 3/4" wood. Particle board was what they recommneded. Now MDF is a common material used for DIY.
If the fuel tank with the thin metal were used, the vibrations by the speakers would eventually loosen or crack any mounting a person could rig up. Probably would sound tinny as mentioned above. I guess a person could bolt a heavy board in front of it for stability but it probably would be easier to remove the tank an build a proper enclosure.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
#14 |
If you build a box to fit your specific location be sure to build it with the proper internal volume for the sub or speaker you are installing into it. This can make a huge difference in the overall outcome. I would also go with a sealed box, in a small cab like our trucks have I cant imagine you would need a ported box. Ported boxes are bigger and harder to get tuned properly, especially if you are limited in the dimensions that you have for your box.
This is a decent site for box calculating, as well as other car audio related topics. http://www.carstereo.com/help/articles.cfm?catid=1 |
#15 |
Well I decided to try it out. I split the tank in half and cut out the peice I was going to use. I sanded it down and painted it, and then lined the inside with peal and seal. I then made 3/4 inch MDF sides, and a front. Before I attached them I used 3/4 inch weather strip and applied to all mounting spots. Then I screwed it all together. I used some duroglass filler to fill a few blemishes on the ends. I carpeted the whole thing. I will let you know how it sounds when I get ready to do the final install on it. If it sounds like crap I will start over and use all MDF. I'm hoping it works though and it fits in the cab perfectly using 3 upper, and two lower gas tank mounts.
#16 |
I will be useing all polk audio speakers. 4 DB 6.5, 2 in the console and 2 in back coners where I made the MDF speaker holders. The sub will be 8" polk DB series also.
#17 |
I like my gas tank one reason I like these trucks that good old gas cap on the cab
72 GMC super custom. ![]() |
