Old 11-01-2006, 08:55 AM   #1
RicksTrucks
RicksTrucks's Avatar
86 motor in our trucks
Will a motor, 350, out of an 86 Silverado drop into our trucks? What year did carburation stop?
68 Short Stepside C-10
69 SWB C-10
70 Flatbed C-20
70 LWB C-20 BB402
70 LWB C-10 CST
70 LWB C-10 CST
71 Short Stepside Cheyenne C-10
72 LWB C-10
72 Blazer 4x4 4spd
95 Jeep Cherokee 4x4
RicksTrucks is offline   Reply With Quote
Old 11-01-2006, 01:05 PM   #2
woodridge
woodridge's Avatar
Re: 86 motor in our trucks
86 should be TBI, change the intake and put a carb on it and you should be good to go.
SEMA Network- Protect our Hobby!
71 C30 in pieces, starting to come together.
Click here for A Place For Tennessee Truck Enthusiest To Meet
woodridge is offline   Reply With Quote
Old 11-01-2006, 01:10 PM   #3
HuggerCST
HuggerCST's Avatar
An 86 truck engine would be carb I believe. I think 87 was the first year for TBI in trucks, but I could be wrong. Should bolt right in, but will have lots of emission crap on it.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 11-01-2006, 01:22 PM   #4
lilpup69chevy
67-72 parts finder
lilpup69chevy's Avatar
87 was the first year for tbi in trucks, 86 would be a carb engine but i'd make sure it was a 350 first most 86 trucks had the 305 unless it was a 3/4 ton or a ton truck, the 86 350 would have had small valves more than likely, it could have 882s' i imagine which are 76 cc 194, 150 valves and those can be made fairly decent, but if its a driver yes it will work only thing is to be correct you will have to use the short water pump because it will have the long pump hope that helps
1969 chevy shortstep 2wd (under construction)
1981 chevy scottsdale lwb 2wd (parts chaser)
2004 pontiac gto (daily driver)
2004 pontiac grand prix gt (the ol ladys car)
1985 chevy short wide
1970 chevy c10 lwb (another parts rig)
1969 gmc lwb (rainy day project)
1968 chevy lwb c10 250 I6 3 spd (soon to be swb)
lilpup69chevy is offline   Reply With Quote
Old 11-01-2006, 09:15 PM   #5
Blue85
Oilfield Trash
Blue85's Avatar
Maniflods probably are a bit different, but if you have headers it shouldn't matter, when i swapped 73 motor in my 85 i had to use the manifolds that came on the 73 engine, can't remember exactly why though.
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 11-01-2006, 10:24 PM   #6
Crank
Crank's Avatar
I think the reason Blue85 used the early manifolds is because of the dipstick location. I got an early engine in my '86 and doesnt have a dipstick because the manifolds are stock on that truck... I just change the oil alot
Brandon
Crank is offline   Reply With Quote
Old 11-01-2006, 10:44 PM   #7
Boog
laying low
Boog's Avatar
Yes you can use the 86 engine in your truck. I have an 88 engine in my 69. The blocks are the same physically. You need to use the rams horn manifolds or headers. If you get an injected engine you can swap to a carb by swapping the intakes. You may have to mod the 2 center manifold bolt holes on each side of the stock intake as the later models are drilled straight up. No big deal. I have an Edel performer intake on mine with stock quadrajet and headers.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 11-02-2006, 12:40 AM   #8
dave2953
Dave's not here, man
dave2953's Avatar
I have a 305 in my 68 that came out of an 86. I just took the 86 manifold off and put my carb/intake from my old 307 on and it worked fine. As mentioned above, I used my factory ram horn manifolds. It was a direct swap.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 11-02-2006, 12:44 AM   #9
Blue85
Oilfield Trash
Blue85's Avatar
Brandon
Yep, that is what the problem was!
87 Chev 3+3 4x4
Old 11-02-2006, 02:16 AM   #10
lilpup69chevy
67-72 parts finder
yes some have the dipstick on either side, the 80's were some wierd years for that as well
Old 11-02-2006, 02:17 AM   #11
lilpup69chevy
67-72 parts finder
to whom is using the 88 block if it was the tbi engine i would assume you have a electric fuel pump? i have an 88 engine in my blazer and all the late model engines have what looks like the spot for the manual fuel pump but it is not machined out
Old 11-03-2006, 10:04 PM   #12
Boog
laying low
Boog's Avatar
Lilpup. I do have the 88 truck engine in my 69. Originally a tbi engine but now carb'd. The block is bored for a mechanical pump and it came with a blockoff plate bolted to it. Some 88 and 89 blocks still had the mech fuel pump provision. Later on the blocks were cast without the pushrod hole in them. All I had to do was remove the blockoff plate and install the pushrod and pump. It's no big deal to install an electric pump inline if your block isn't bored for the mech one.
Boog
primer is finer
Old 11-04-2006, 03:18 PM   #13
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Mine has a 350 out of an 89 Chevy in it, bolts right in
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 11-04-2006, 03:41 PM   #14
lilpup69chevy
67-72 parts finder
mine had the blockoff plate bolted on it but when i took it off it wasn't machined for the mechanical pump so i just used in inline electrical pump works fine, maybe this block wasn't an 88 as said it was thats what the guy told me i know at first it had the centerbolt heads on it then i ditched them
