Old 11-01-2006, 12:52 PM   #1
caseychoptop
caseychoptop's Avatar
generater light
little question regarding the generater light on the dash board, not having had this truck long and not used it at night much i havent noticed before but just used my truck and the generater light stays on, is it meant to do this if not what does it mean
ps where should the main beam indicator be on the dash
caseychoptop is offline   Reply With Quote
Old 11-01-2006, 03:02 PM   #2
caseychoptop
Re: generater light
does anyone have any ideas, dont want to drive my truck if the battery is not charging
Old 11-01-2006, 03:14 PM   #3
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Re: generater light
Sounds like your "not" charging. The light should only come on before the motor starts.If you have a multimeter check the voltage at the battery before starting, should be around12.7 or so then after truck is running should be around 13.9 to 14.9. The high beam indicator is at top of the speedometer.
sneakysnake is offline   Reply With Quote
Old 11-01-2006, 03:15 PM   #4
67ChevyRedneck
67ChevyRedneck's Avatar
Re: generater light
Typically the "generator light" should turn on when you turn the key on, then it should turn off when you start the truck. It means your truck has a bad battery, alternator, or voltage regulator. BUT with these trucks being so old, something may be hooked up wrong somewhere, or came unhooked, or has a bad ground wire.
I circled the high beam indicator light, (I think that's what you were asking about)
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 11-01-2006, 03:16 PM   #5
67ChevyRedneck
Re: generater light
OOPs, I was a little slow, oh well.
Jesse James
Project "On a Dime"
Old 11-01-2006, 04:56 PM   #6
caseychoptop
Re: generater light
could anypost a pic of the voltage regulater please and where it is locatted, still trying to find my way around this truck not having had anything like this before, also pic of the generator would be great aswel please, cheers for everyone help
Old 11-01-2006, 05:49 PM   #7
67ChevyRedneck
Re: generater light
The generator is just another word for the alternator, but depending on your motor it could be on DS or PS. It would be at the front of the motor with a few wires going to it. It's one of the belt driven items.
The voltage regulator is a little black box on the driverside of the core support at the front of the engine. It should be on the backside (engine side) of the core support and have a wire harness going to it. These typically don't go bad. Places like autozone should be able to test both your battery and alternator for you. My guess would be a bad battery or alternator.
Jesse James
Project "On a Dime"
Old 11-01-2006, 06:37 PM   #8
alblogg
alblogg's Avatar
Re: generater light
I don't know if they have any Auto Zones in England yet there 69ChevyRedneck but I borrowed one of your pictures to give him an idea. I circled the alternator (generator) the regulator is a small black box on the radiator support follow your wires from the alternator and you will find it.
'07 G6 Wife's car
'00 Malibu stock, just a parts getter.
'99 Blazer LT Loaded, K&N Filter, Pioneer Super
Tuner,Viper
'88 K1500 Cheyenne, 5.0, stock, bought new
'86 Nissan 720 Trash Truck
'69 C/10 step side, 307, all original, second owner, in process of restore.
The person who says it cannot be done should not interrurt the person doing it.
Share your knowledge. It is a way to achieve immortality.
Allen- Paintman
Wrenchtwister
Broompusher
alblogg is offline   Reply With Quote
Old 11-01-2006, 06:53 PM   #9
chevybill
chevybill's Avatar
Re: generater light
You can also start your truck and remove a battery cable with the truck running and if it dies, it is running off the battery.
ongoing 1970 c 10 lwb
1994 z-28 few mods.-owned since new
1978 vette silver/grey 25th anniv. paint
chevybill is offline   Reply With Quote
Old 11-02-2006, 12:33 PM   #10
caseychoptop
Re: generater light
if it dies when i remove the battery wire while running does that mean it needs a new battery
Old 11-02-2006, 12:40 PM   #11
sneakysnake
Re: generater light
NO. it means your charging sys is not working.
Old 11-02-2006, 12:43 PM   #12
67chevemall
67chevemall's Avatar
Re: generater light
This is a simple and great test.
You can tell right away if it is your Alt or Batt
Cheers
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 11-02-2006, 12:43 PM   #13
67ChevyRedneck
Re: generater light
I kept looking at that picture (before I read your post) thinking, damn, that engine bay looks REALLY familiar Guess I didn't recognize it 'cause the truck is blue now
Jesse James
Project "On a Dime"
Old 11-02-2006, 04:13 PM   #14
sneakysnake
Re: generater light
Cheers
If the battery was bad the truck wouldnt turn over or was draining over night . A bad battery wont make the alt or gen light come on.Also this is a good way to knock the diodes in the alt.
Old 11-02-2006, 07:10 PM   #15
caseychoptop
Re: generater light
di the test by removing battery lead, it was the battery that was knackered, picking up new battery in the morning, what will be causing the generator light to come on then if not the battery????
Old 11-03-2006, 11:07 AM   #16
sneakysnake
Re: generater light
When you pulled the wire off the battery did the truck die?
Old 11-03-2006, 11:13 AM   #17
67chevemall
Re: generater light
so what happened?
The truck stayed running when you pulled the wire off?
Old 11-03-2006, 11:16 AM   #18
67chevemall
Re: generater light
OT this is good to know. Even when you upgrade to the 7 gauge dash, I belive it is a great benifit to keep a gen light.
If somebody knows where the gen light gets its current from I might hook one up.
Old 11-03-2006, 11:31 AM   #19
sneakysnake
Re: generater light
pic
Old 11-03-2006, 11:35 AM   #20
sneakysnake
Re: generater light
so what happened?
If the it stays running then your alt is putting out.If the truck dies then you have a charging problem.
Old 11-03-2006, 03:14 PM   #21
caseychoptop
Re: generater light
the truck stayed running when i pulled the battery lead, so have new battery, not fitted yet as been working, should the gen light go out with new battery fitted?
Old 11-03-2006, 04:39 PM   #22
sneakysnake
Re: generater light
If the old battery was starting the truck,and the truck would run unhooked from the battery then I doubt the new battery will make the light go out.
What normally turns on the alt light is an internal short to ground.So its possible that even though its charging somethings not quit right.
What I would do if the new battery doesnt cure it is replace the voltage regulator(external) and have the alt spun tested at a parts store but that may not be a solution judging from your location.
Old 11-04-2006, 12:49 PM   #23
caseychoptop
Re: generater light
new battery is in, gen light is still on but alot dimmer, truck has the upgrade to altenater so voltage regulater should be bypass right
Old 11-06-2006, 11:58 AM   #24
sneakysnake
Re: generater light
If you have the "internal" voltage regulator it should be wired like the diagram in post#19. I bet you are going to have to replace or rebuild the Alt.
Old 11-06-2006, 03:43 PM   #25
caseychoptop
Re: generater light
altenater has been tested and is all good , looks like the last owner did the upgrade anyway so doesnt look that old, any other ideas to way the gen light is staying on
