11-01-2006, 01:06 PM | #1 |
SW Gauges
Would I experience any problems with SW gauges ( mechanical) if I put them in a 67-72 truck?? Would the speedo cable end be the same??? Would the gas gauge work right??? etc. etc.
11-01-2006, 04:40 PM | #2 |
Re: SW Gauges
ttt
11-02-2006, 12:08 AM | #3 |
Re: SW Gauges
Someone out there must have used Stewart Warner Gauges at one time or another. I am curious mainly if the speedo cable will work from a 67-72 truck and the sending unit from the tank to the SW fuel gauge??????
11-02-2006, 12:19 PM | #4 |
Re: SW Gauges
You shouldn't have a problem. Most guage kits come with the correct sending units to operate the gauges. You may have to change the plastic gears in your tranny tail cone to get the speedometer to read correctly. Or you could get a electric speedometer, which will allow you to reprogram it for any tire or gear size.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
11-02-2006, 12:48 PM | #5 |
Re: SW Gauges
Sounds like the cable to speedo nut should be the same???
11-02-2006, 02:24 PM | #6 |
The Hammer Man
Re: SW Gauges
can i ask what ttt means ?
Boise69. Bought in Boise ID and its a '69 ___________________________________________ 1969 Chevy C-10 SWB 350/400 - drivable project www.americanhammer.com 2013 MBZ Sprinter customized 2005 MBZ Sprinter Van 2004 Land Rover Discovery 2001 Yamaha Road Star 1997 MBZ E420 1989 Ferrari Mondial T |
11-02-2006, 03:05 PM | #7 |
Re: SW Gauges
ttt Now watch what happens to the post/thread
11-02-2006, 06:01 PM | #8 |
Freeeeee Mason...
Re: SW Gauges
TTT = To The Top. Bumps up the post
11-02-2006, 06:10 PM | #9 |
Re: SW Gauges
I have some old style SW gauges in my truck, they were in when i purchased the truck..the spedo works but reads the incorrect mph, the gas gauge reads backwards: full= almost empty. 1/2=full.... the volts gauge+oil pressure+tach works properly, i havent looked into why the other gauges dont work properly because i am replacing them all with autometers anyway.
