11-01-2006, 03:16 PM | #1 |
Can you identify this axle?
Just as the title states. Can you identify this axle? Is there enough there to give any identifing marks? This is under an '85 Chevrolet front end. Guesses? This vehicle is being shipped to me but it's killing me to know the drive train. Here is another thread with a little more detail. Another thread
11-01-2006, 03:16 PM | #2 |
Re: Can you identify this axle?
This is the only pictures of the front end that I have so far.
11-01-2006, 03:41 PM | #3 |
Sb 400 club
hmm i can't tell by those pics but looks nice and clean !!!!
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
11-01-2006, 04:19 PM | #4 |
Slots go on anything!
Is that 'burb a 1/2 ton? If it is, then that should be a 10 bolt, if it's factory.
11-01-2006, 04:48 PM | #5 |
Chris
I'd bet it's a gm 10-bolt because it has little fangs on bottom just like my 86 1/2 ton.
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
11-01-2006, 04:50 PM | #6 |
ROCK*STAR
Looks like a 10 bolt. They have these tabs at the corners.
11-01-2006, 05:00 PM | #7 |
It's a burb 3/4 ton. It has the full float rearend so it is 8600 GVWR.
11-01-2006, 05:21 PM | #8 |
7000 #'s of american IRON
uneducated guess: 14 bolt rear/10 bolt (maybe 12 if they exist, but i'm thinkin 10) bolt front
11-01-2006, 06:04 PM | #9 |
It is definately a 10 bolt front.
11-01-2006, 06:12 PM | #10 |
It's probably still a 10 bolt in the front.
11-01-2006, 10:31 PM | #11 |
www.73-87chevytrucks.com
Unless it was swapped out, it is a 10bolt which is factory. There were no 1T Burbs, so no D60 from the factory.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
11-01-2006, 10:44 PM | #12 |
Location: vacaville ca, because it as far from indy as i can be
you can see the ball joints from here, see how the axle C is above knuckle at the top and bottom. d60's the knuckles go over the axle C on top and under on bottom.
11-02-2006, 01:20 AM | #13 |
Professional Grade
Yep, that'd be a 3/4 ton 10 bolt. Has two u-bolts on the pass side too, D60 only has one.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
