Old 11-01-2006, 10:39 PM   #1
seanu
Too many projects!!!
seanu's Avatar
89 Burb..no fuel from injectors! Need help!
My wife was driving the 89 burb 4wd today and it just shut off on her.
I have narrowed it down to no fuel from the injectors, they have just shut off. I have fuel up to them (checked that)..but they are not firing.
Does anyone know what would shut down the injectors? I know on my 91 Olds it has a low oil shut off, but I didn't think the burb had that??
Any thoughts, or ideas?
thanks
Sean
1995 Buick Roadmaster Sedan
2004 Chevy Trailblazer 5.3L V8
1963 Chevy Biscayne 4D Sedan
1971 Chevy C10 (now have 70 cab & frame)
1968 Chevy C10 (parts for the 70)
1991 Oldsmobile Custom Cruiser (Chevy 355 motor)
1937 Pontiac 8 4D Touring Sedan (in pieces)
Jacksonville, Florida
seanu is offline   Reply With Quote
Old 11-02-2006, 06:45 PM   #2
Jonboy
Slots go on anything!
Re: 89 Burb..no fuel from injectors! Need help!
you might check to make sure the wiring at the plug is intact. Also, check the oil pressure gauge. the sending unit for the oil pressure gauge also has a low pressure switch on it, and will kill electricity to the pump on an EFI truck.
Old 11-03-2006, 10:15 PM   #3
seanu
seanu's Avatar
Yeah...the pump is running fine..I already checked that...but I did find out that the Ignition Control Module can go bad and when that happends, it doesnt send a signal to the ECM to tell it to fire the injectors.
I am going to check the ICM tomorrow, by swapping it out with another and see if that solves the problem.
Sean
Old 11-04-2006, 12:45 AM   #4
Russell
Professional Grade
Russell's Avatar
Ignition module would be my guess as well
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 11-04-2006, 09:59 PM   #5
seanu
seanu's Avatar
Well, the ICM didn't fix the problem...it was in the dist. it's-self. The magnetic pickup on the dist must have gone bad...took a new dist. to fix the problem.
So it's fixed... but it cost me $100 bucks
Sean
Old 11-10-2006, 01:13 AM   #6
aggiedave98
so how did that cause it to stop giving you fuel? curious so i know for the future... thanks.
aggiedave98 is offline   Reply With Quote
Old 11-29-2006, 01:55 AM   #7
USAFgunner
USAFgunner's Avatar
Cause it provides a reference to the ecm to fire the injectors. ECM controls the ground circuit on the injector
Giving the enemy the opportunity to die for their country
USAFgunner is offline   Reply With Quote
Old 11-29-2006, 09:41 AM   #8
aggiedave98
ahhhh, thanks!
