11-01-2006, 10:42 PM | #1 |
C10 and C20 frame & suspension differences?
I have a 1972 C10 longbed with coil springs front and rear. The springs on the truck seem quite tired. I am considering installing 3/4 ton springs all around to lift the truck up a bit. I understand that this should raise the truck about 2 inches over the stock original height. I was wondering if this would even work? I figure the hubs, spindles, springs, brakes, and rear axle are all different from a C10 to a C20. So would the coil springs interchange? If so would the truck front end still allign correctly?
I will most likely install new heavy duty C10 springs front and rear, but I just wanted to explore my options and learn about the differences. Thanks, Erik Last edited by Texasdeere; 11-01-2006 at 10:43 PM. |
11-02-2006, 12:44 AM | #2 |
its all about the +6 inches
Re: C10 and C20 frame & suspension differences?
HD C/10 springs are the same as C/20 springs.
Although, I dunno about 2 inches... onless yours is really saggin right now. |
11-02-2006, 03:33 PM | #3 |
Thanks,
I thought that might be the case. My front end has spring spacers and sits at a normal height. The rear end sits level with the front and is resting on the overload leafs. |
