Old 11-02-2006, 02:16 AM   #1
bad_turbo
turbo enthusiast
bad_turbo's Avatar
1 ton brakes
trying to find info on swapping my drums for discs. I have a '69 1 ton with drums on the front and I was told that 3/4 ton disc brakes will not work on my truck. Do I need to find a newer 1 ton with disc brakes to achieve my goal? Thanks
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 11-02-2006, 04:37 AM   #2
junkyardjohn
junkyardjohn's Avatar
Re: 1 ton brakes
I've Yet To Get Around To Putting It In, But I've Got A Whole Front Cross Member & All The Steering Up To & Including The Steering Box Off Of An 85 I Ton. This Is For My 69 1 Ton Tow Truck. It'll Go In During The Next Motor Swap. It Seems Like It Was $120 From A Pick -n- Pull Boneyard. Beware... There Heavy Suckers. John
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 11-02-2006, 11:26 AM   #3
Jim_PA
Re: 1 ton brakes
Do you know for a fact that the 85 front crossmember will fit? I've read that the 1/2 ton trucks are a pretty simple job just re-drilling a few holes, but never heard about doing this to a 1 ton.
What are you doing for the booster and master cylinder?
Jim_PA is offline   Reply With Quote
Old 11-02-2006, 01:50 PM   #4
shaneschevys
Its always something!
shaneschevys's Avatar
Re: 1 ton brakes
I used a 89 1ton front susp under my 69. I had to redrill the 4 holes on the side of the frame because the 89 used a bigger bolt. But other than that it bolted right in.
79 p10 stepvan
72 Short Fleetside
72 Suburban
67 GMC One Ton Flatbed
64 Short Fleetside
57 Chevy 2DR Hard Top
57 Chevy 2dr wagon
65 f*** short fleet
63 C 60 Flatbed
Member of the patina club
shaneschevys is offline   Reply With Quote
Old 11-02-2006, 01:51 PM   #5
Jim_PA
Re: 1 ton brakes
Cool -- and what did you do for master cylinder/booster and prop valve?
Old 11-03-2006, 02:07 AM   #6
shaneschevys
Re: 1 ton brakes
The 89 had a hydro boost on it. So I used it , the 89 master cyl, prop valve & brake lines. Had to modify the brake pedal for the hydro boost.
79 p10 stepvan
72 Short Fleetside
72 Suburban
64 Short Fleetside
57 Chevy 2dr wagon
65 f*** short fleet
63 C 60 Flatbed
Old 11-03-2006, 10:07 AM   #7
Jim_PA
Re: 1 ton brakes
Cool -- thanks! -- and sorry for the thread hijack
