Old 11-02-2006, 10:47 PM   #1
dhill3443
Chevy pulling Camper
dhill3443's Avatar
Emissions Routing
Wondering if anyone has or knows where I can get the vacuum route decals or schematics on emissions for a 1985 C10 Scottsdale. 305 Engine, 350 transmission. Mine are totally screwed up by the previous owner.
dhill3443 is offline   Reply With Quote
Old 11-03-2006, 03:08 AM   #2
blaserman
blaserman's Avatar
Re: Emissions Routing
Would the routing ne the same from a 86 Blazer? If so I think I still have something on it left from mine.
Art
This is my best friend
blaserman is offline   Reply With Quote
Old 11-03-2006, 07:56 AM   #3
dhill3443
dhill3443's Avatar
I'm not sure but I'll check on it today. Thanks
Old 11-03-2006, 12:04 PM   #4
wedgemon
wedgemon's Avatar
Is there any of the old decal left?? There's a code number in one of the corners.
2003 Silverado K1500 Z71 - Arrival Blue
1973 K5 Cheyenne Blazer 350/TH350/NP203
Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift.
RETIRED: 1980 Scottsdale 4x4
Founding Member:
"TILT WHEEL BELLY." Club
wedgemon is offline   Reply With Quote
Old 11-03-2006, 12:08 PM   #5
wedgemon
wedgemon's Avatar
BTW The diagram above is for 1985 305 (5.0L) V8 engine — 4bbl federal low altitude with automatic transmission. Code UHJ.
- Dave
Founding Member:
Old 11-03-2006, 02:34 PM   #6
dhill3443
dhill3443's Avatar
No none of the decals are anywhere except the glove box decal of the truck explaing the package. I've drawn a diagram of what I have and what your decal looks like is identical to what my lines look like even the sensors. My truck is a 1985 with a 305 engine and 350 turbo trans. I think mine had a couple more vacuum lines that are on sensors on the fire wall. One wire goes to the A/C and the other to a box inside the truck behind the glove box. I have no earthly idea what that box is doing. My HEI or nothing else is hooked up to it. But a 4 prong connector is out under the hood beside the engine with nothing hooked up to it. I think someone must have removed something. I have to find a wiring diagram also for this model. I need to find out the idle, low and high, and the timing. Thanks
Old 11-08-2006, 11:46 PM   #7
dhill3443
dhill3443's Avatar
Thanks for the diagram. I believe most of it will work. I have a few more items on mine I have to figure out especially the box behind the glove compartment. Thanks again.
