Old 11-02-2006, 11:45 PM   #1
trlrider77
Out of money
trlrider77's Avatar
Camshaft info
I need to know where i can find info on a cam that was in my truck. The end is stamped 151 H3. Is there a site or some other way to find out what it is? The guy I bought the truck from said he bought it from a local Chevy dealer but couldn't remember what it was. The dealer changed hands around 13 years ago. He did say it was around $300. I think thta it is a gm part but I am not for sure.
trlrider77 is offline   Reply With Quote
Old 11-03-2006, 01:19 AM   #2
davidh
davidh's Avatar
Re: Camshaft info
I wonder if that is the famous 151 327 350HP cam? Crane makes an identical however it's outdated technology. I think a great all around cam for a 350 in a truck with intake, and duals is the 268 comp cam..
davidh is offline   Reply With Quote
Old 11-04-2006, 01:02 AM   #3
trlrider77
Out of money
trlrider77's Avatar
Re: Camshaft info
The cam still looks ok. Would it be worth using it. Odes anyone know the specs?
Old 11-04-2006, 01:13 AM   #4
crazy longhorn
Fabricate till you "puke"
Re: Camshaft info
The 151 cam was .447 lift(both intake & exhaust), & 221.5 duration @ .050 both sides. IIRC, it was ground on 112 lobe separation angles. It was a wild streeter in its day......you should hear it in a hot 283! The cam is old school, & still does work well in a high compression pump fuel mill........but there is much more power to be found in the newer grinds. L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
