Old 11-03-2006, 03:04 PM   #1
El Nido Kid
Inline 6 exhaust leaks
Can anybody help me find a source for a better quality exhaust gasket? I had the manifold surfaced but the head has some minor pitting an the stock (metal on both sides gasket) just isn't making it.
El Nido Kid is offline   Reply With Quote
Old 11-03-2006, 03:09 PM   #2
Ram-Man
Ram-Man's Avatar
Re: Inline 6 exhaust leaks
I think you need 2 gaskets one for each side of the 4 cylinders. So pull the motor and slap in a small block. No just kidding, you should be able to get Fel Pro in a synthetic gasket and not all metal one.
Ram-Man is offline   Reply With Quote
Old 11-03-2006, 04:36 PM   #3
I used some Permatex High-Temp Ultra Copper RTV Silicone Gasket Maker on my 250 with NAPA gaskets and never had a leak or an issue.
Old 11-03-2006, 08:52 PM   #4
Brad
Out of the carpool lane.
Brad's Avatar
When you machined the manifold did you have them both bolted up together? Or did you only do the exhaust?
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 11-03-2006, 09:05 PM   #5
El Nido Kid
They were bolted together with a new gasket that didn't leak.
Old 11-04-2006, 02:37 AM   #6
Brad
Brad's Avatar
Take a look at my post (3rd one down) here:http://67-72chevytrucks.com/vboard/s...d.php?t=209362
This is a good way to make sure everything seals well. If you still have an exhaust leak, could it be coming from the area where the donut is? That's been a problem for me when I had stock exhaust. Make sure the tail pipe is squared up to the outlet port when you're bolting it all together and always use a brand new exhaust donut. Let us know...
Old 11-04-2006, 07:59 AM   #7
'68OrangeSunshine
'68OrangeSunshine's Avatar
I've had to replace some of the OEM bolt fasteners with studs. Especially on the ends [#1 + #8], where the stock set up uses non-threaded guide pins.
Of course I'm running an Offy intake and Clifford headers on a 292 L6, but studs [3/8-16 UNC_3/8-20 fine thread] would give you much better holding even with a stock manifold.
For the gasket, the FelPro metal one [with Permatex Copper-Spray-A-Gasket] ought to work. The NAPA one is the same thing.
'68OrangeSunshine is online now   Reply With Quote
Old 11-07-2006, 12:35 AM   #8
El Nido Kid
Just curious --- are the fixed studs at the ends threaded into the head or do you have to drill and tap? The latter would not be an inframe chore as I see it.
Old 11-07-2006, 01:07 AM   #9
Brad
Brad's Avatar
They are screwed in. Just get a Vice-Grip plier and unscrew.
Old 11-07-2006, 08:00 AM   #10
'68OrangeSunshine
They come out CCW with some WD40, big vice grips and a small ball pien. The holes are already tapped 3/8-16 UNC. The studs are about 3" long and the first inch is threaded 3/8-16 then about 1/2 inch of non-thread and ending with about 3/4 of a finer thread 3/8-20 -or -24 [whichever]. Common at fastener suppliers. A flat washer, a lock washer and the nut complete the set up.
