Old 11-03-2006, 08:50 PM   #1
ghackett1
68 C10 Longbed
ghackett1's Avatar
Is Original tach compatible with HEI ??
I just purchased the tach conversion set up for my 71 c-10 pick up. But the directions said the new repro tach is not compatible with an HEI distributor which my truck has (late 70,s gm style). Do I need to put a points distributor back in or what? Please let me know as I want to complete this project now that I have my new parts! Thank you.
ghackett1 is offline   Reply With Quote
Old 11-03-2006, 09:01 PM   #2
Machu10
Junior Member
Machu10's Avatar
Re: Is Original tach compatible with HEI ??
i have a factory repop tach connected to my crate 454ho, it works like a charm.
72 Cheyenne Super ShortBox, Factory Big Block, A/C PS PB.
71 Cheyenne LWB, 350, A/C, 48k Miles
70 Olds Cutlass Convert, A/C, 350 auto, 66k actual miles.
82 Corvette, Triple Black, 32k Miles, Had since new.
85 Caprice Coupe, Bottle fed 383 Stroker, 30k miles.
06 Dodge Charger Daytona, Top Banana Hemi.
Machu10 is offline   Reply With Quote
Old 11-03-2006, 09:32 PM   #3
crm318
Alright Alright Alright
crm318's Avatar
i have a repo tach in my 72 cheyenne with a 350 and hei. it works great and is just the look i was going for.
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 11-03-2006, 09:43 PM   #4
ghackett1
68 C10 Longbed
ghackett1's Avatar
Okay thanks for the help. When I purchased the kit I could not see why there would be a problem so I was surprised to see the quote that said "Will Not Work With Hei". I'm gonna hook it up this weekend. I'll update you on the progress. Thanks again.
Old 11-03-2006, 09:48 PM   #5
Huck
Huck's Avatar
the HEI system uses a different wave length of signal that the tach picks up. The original tach's were far from accurate running off the stock distributor and when hooked up to an HEI dist, they are off a bit more but--I too am running an aftermarket reproduction of the original on my 350 with HEI and have had no problems.
Huck is offline   Reply With Quote
Old 11-03-2006, 10:05 PM   #6
msgross
msgross's Avatar
my original tach doesn't seem that bad with HEI. Maybe I should hook up an aftermarket to see the difference....
msgross is offline   Reply With Quote
Old 11-03-2006, 11:18 PM   #7
corn
I was told they do that so they can sell you their adaptor for another $100. All it is, is a piece of wire with the HEI plug on the end of it...
corn is offline   Reply With Quote
Old 11-04-2006, 10:30 AM   #8
ghackett1
68 C10 Longbed
ghackett1's Avatar
Thanks again for the quick responses. I'm new to the site and just purchased a 71 custom deluxe Big Block original motor truck! Its my baby, as soon as I get some pics I'll post them. Thanks.
