Old 11-03-2006, 09:45 PM   #1
crm318
Alright Alright Alright
crm318's Avatar
head bolts and pushrods for vortec heads
i am building a vortec headed 350 and i was wondering what head bolts an pushrods i should use. will regular pushrods and headbolts that fit a 87-95 tbi motors work? (its going on a 89 350)
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 11-03-2006, 10:25 PM   #2
seanu
Too many projects!!!
seanu's Avatar
Re: head bolts and pushrods for vortec heads
When I built my 355, with Vortec heads. I used a set of stock length pushrods used on any standard sbc, I did get hardend ones though.
I also used standard head bolts...the only difference in the vortec heads really, is the internal design of the head..and you will have to use self alinging rockers.
Sean
1995 Buick Roadmaster Sedan
2004 Chevy Trailblazer 5.3L V8
1963 Chevy Biscayne 4D Sedan
1971 Chevy C10 (now have 70 cab & frame)
1968 Chevy C10 (parts for the 70)
1991 Oldsmobile Custom Cruiser (Chevy 355 motor)
1937 Pontiac 8 4D Touring Sedan (in pieces)
Jacksonville, Florida
seanu is offline   Reply With Quote
Old 11-04-2006, 09:01 AM   #3
Blazer1970
Blazer1970's Avatar
The head bolts and push rods are the same as any other SBC. You can use your old ones if they are in good condition.
Blazer1970 is offline   Reply With Quote
Old 11-04-2006, 09:17 AM   #4
junkyardjohn
junkyardjohn's Avatar
ALOT OF PEOPLE CLAIM YOU CAN'T OR SHOULDN'T REUSE HEADBOLTS. I'VE DONE IT DOZENS OF TIMES ON BOTH SMALL & BIG BLOCKS WITH NO FALURE. JUST WIRE WHEEL THE BOLT THREADS GOOD & RUN A TAP THRU THE THREADED HOLES TO CLEAN THEM OUT GOOD. INSPECT YOUR PUSHRODS REAL WELL. IF THEY ARE NOT BENT, & THE ENDS LOOK GOOD.... THEY ARE O-K TO REUSE TOO, BUT IF YOU USE GUIDE PLATES THEY SHOULD BE HARDENED. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 11-05-2006, 07:39 AM   #5
GMCPaul
The head bolts will work fine and so will the pushrods if you be sure to use self-aligning rockers though as standard rockers will dance sideways on ya and pushrod will end up bent, if you don't use self-aligning rockers then you will need to have heads drilled for guide plates and use harded pushrods.
I use the pro-form self-aligning roller rockers from Summit, great price coupled with a great performing rocker on needle bearings, you can buy the GM self-aligning rockers that are stamped steel and look like stock rockers but the price is esstentially the same as roller rockers so in my book rollers are the way to go.
GMCPaul
GMCPaul is offline   Reply With Quote
