Old 11-03-2006, 09:58 PM   #1
BigA
Intake Gasket Maker What Kind
I'm getting ready to replace my front and back intake gasket because of leakege and would like to know what RTV sealant to use. I have ultra black Hi-temp #598B- blue rtv 6b and would like to know which one is best to use. I also would like to know if I shoud use the clear rtv adhesive sealant on the intake bolt threads. I have a 350 with a weiand intake.
BigA is offline   Reply With Quote
Old 11-03-2006, 10:03 PM   #2
dave2953
Dave's not here, man
dave2953's Avatar
Re: Intake Gasket Maker What Kind
I used the black for my intake. It worked beautifully with no leaks. I didn't use the gaskets for the front and rear; I've never had any luck with them so I just use RTV. Not sure about the clear for the bolts. I just cleaned the threads on mine before re-installing. Hope this helps.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 11-03-2006, 10:14 PM   #3
underdog8704
NCStroker
underdog8704's Avatar
heres a whole thread full of differing opinions...http://67-72chevytrucks.com/vboard/s...d.php?t=214085
1971 Chevy C/10-Built 383 Stroker
underdog8704 is offline   Reply With Quote
Old 11-04-2006, 01:13 AM   #4
LockDoc
The Older Generation
LockDoc's Avatar
I used Locktite #2 gasket sealant when I was having problems. No problem since......
LockDoc
Leon
Old 11-04-2006, 02:53 AM   #5
manimal
manimal's Avatar
The ultra black is for use on gaskets that come in contact with oil-such as your intake. The blue is best for water.
manimal is offline   Reply With Quote
Old 11-04-2006, 05:51 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The right stuff.
Old 11-04-2006, 06:48 AM   #7
centsless
sufficiently talented fool
centsless's Avatar
Use the black for the intake ends. Get some liquid teflon sealant for the bolt threads.
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 11-04-2006, 09:24 AM   #8
junkyardjohn
junkyardjohn's Avatar
I ALWAYS USE BLUE RTV SYLICON SEALENT & FEL-PRO GASKETS ON INTAKE MANIFOLDS & I ALWAYS SEAL THE THREADS WITH THE SAME SEALER I USE ON THE HEAD BOLTS. (IT KEEPS OIL FROM WORKING UP AROUND THE THREADS & LAYING ON YOUR INTAKE. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 11-04-2006, 09:51 AM   #9
jamon8
jamon8's Avatar
do you have aluminuim or cast heads
It makes a difference on which type of thread sealant you use
jamon8 is offline   Reply With Quote
