Old 11-04-2006, 02:21 AM   #1
JTK20
Active Member
3/4 ton & 1 ton frame differences?
What, if any, are the differences between the 3/4 ton and 1 ton frames in the 73-87 trucks? I'm looking at getting a 3/4 ton frame with a 350 engine, SM465 transmission, NP208 t-case, axles, and wheels (all with 87k original miles) for $475. Frame is straight and any heavy rust has been removed. I want it to do a heavy diesel build (Cummins, Detroit, or IH) and will swap out the axles for 14 bolt ff rear and Dana 60 front. However, if the frame is heavier on the 1 ton then I'd rather hold out for that. Also, does $475 sound like a good deal for all that?
JTK20 is offline   Reply With Quote
Old 11-04-2006, 02:33 AM   #2
manimal
manimal's Avatar
Re: 3/4 ton & 1 ton frame differences?
I have a 1 ton 4x4 gmc-1979. The frame is quite a bit bigger than a 3/4.If I not mistaken the 1/2t and the 3/4t share the same frame. The price isnt too bad as long as its a complete rolling chassis. I found my truck-drivable for 1800. I may also be getting a crewcab 1ton srw 4x4 with a 6.2 deisel for 350.00.
manimal is offline   Reply With Quote
Old 11-04-2006, 02:53 AM   #3
JTK20
Active Member
Well, dangit, I'm all backwards. I thought the 3/4 ton and 1 ton shared the same frame and the 1/2 ton was smaller. Now I feel bad because I told the guy I'd buy his frame and now I have to back out on it because it's not what I want, and I don't feel like parting it out. It is a complete rolling chassis, also has front and rear bumpers, grill, and a grill guard. Oh well. Hopefully he can get a hold of the other guy who wanted it and sell it to him. Man I'm gonna feel like a jackass when I make that phone call tomorrow...
Old 11-04-2006, 03:51 AM   #4
Cadillac_Don
There Are A Heavy Duty 8600 # Option 3/4 Frame and then the regular 7200#
Cadillac_Don is offline   Reply With Quote
Old 11-04-2006, 06:05 PM   #5
72C203503ONTHETREE
72C203503ONTHETREE's Avatar
My 76 3/4 ton 4X4 must have been the heavier duty frame, it had the SM465, NP 205 transfer, heavy duty front Dana 44, and the 14 bolt full floater rear along with no emmisions crap. I was thinking about swapping 3/4 ton suspension and rear into my 73 half ton to.
72 Chevy C20, SOLD (Dang it.)
09 Challanger RT six speed in all black.
74 Datsun 710 wagon, all 1.8 liters of screaming Datsun power.
73 C10 long bed, 350/350 combo, nice shape.
72C203503ONTHETREE is offline   Reply With Quote
Old 11-04-2006, 09:29 PM   #6
edman87
junk collector
1/2 and 3/4 ton have less in common than 3/4 and 1 ton. I don't know for sure, but the heavy 3/4 and the 1 ton are same. the light 3/4 is closer to a half ton but still beefier. I might be wrong on this, but do knoe the heavy gvwr 3/4 ton is very stout and would be great for a heavy buildup and is much thicker and has taller channels than a half.
'87/89/76 K5 in progress
'99 K2500 short crew
'91 camaro rs
'98 jeep tj
'52 willys cj3a
edman87 is offline   Reply With Quote
Old 11-19-2006, 07:04 PM   #7
89 crew
It also depends on the year. the 74 3/4 ton's have a much bigger frame than the 82 3/4 ton. If you want a heavy frame find a 40, 50, or 60 series truck and add the lighter parts to it. if you choose the right one it will already have the mounts for the big diesel in place.
89 crew is offline   Reply With Quote
Old 11-19-2006, 09:21 PM   #8
magnethead
7000 #'s of american IRON
magnethead's Avatar
My 10,000 pound 1 ton frame has something like 8" tall frame rails i thinketh?????
magnethead is offline   Reply With Quote
Old 11-23-2006, 04:53 AM   #9
JTK20
Active Member
Could you put a 10, 20, or 30 series body on a 40, 50, or 60 series frame without doing a lot of fabrication?
