Old 11-04-2006, 03:07 AM   #1
Kenneth_CS87
Do you guys know what plug are these for?
Do you guys know what plug are these for? Its a LT1 motor and do I need it?
Kenneth_CS87 is offline   Reply With Quote
Old 11-04-2006, 03:50 AM   #2
Cadillac_Don
Re: Do you guys know what plug are these for?
Could Be A Vaccum Relay For The Smog Pump?
Cadillac_Don is offline   Reply With Quote
Old 11-04-2006, 07:58 AM   #3
Werewolf
Woof?
Werewolf's Avatar
Gawd, I should know this. But I can't quite remember. The smog pumps on LT-1's are electric, and everything's located up front.
I *think* it's the solenoid that regulates the EGR valve operation. Whether you need it or not depends on whether you want the EGR to function or not. EGR function can be removed in the computer programming.
1968 LWB CST BB
2004 Avalanche Z71 LT3.
2003 S-10 ZR2 (hers).
1997 Astro
1992 Caprice wagon, 500k stock miles. Nursing wounds after a bad wreck.
1997 Saturn - need gas mileage from something!
Werewolf is offline   Reply With Quote
Old 11-04-2006, 03:29 PM   #4
Kenneth_CS87
Im not running the smog pump stuff anymore. So I can just remove it huh?
Old 11-04-2006, 06:20 PM   #5
Werewolf
Woof?
Werewolf's Avatar
Sorry man, my T/A's at the performance shop for cooling issues, so I can't look. I just don't remember otherwise. Your EGR vacuum line should be going into a similar little setup. Check for it.
1968 LWB CST BB
1997 Astro
Old 11-04-2006, 06:46 PM   #6
centsless
sufficiently talented fool
centsless's Avatar
Pic # 1 is the EGR solenoid
Pic # 2 is the evap canister purge solenoid
Pic # 3 My 95 SS does not have that solenoid. it is not part of the air pump system on a 95 Impala SS. Could be if it came out of an F body.If you do not hook them up, it will trigger a check engine light. I am not sure if the PCM will be OK with that. Some trouble codes will force the PCM to go into "limp in" mode. I will look and see later if they will.
Bob
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 11-04-2006, 06:48 PM   #7
centsless
centsless's Avatar
After looking closer, the motor does appear to be f or y-body. (Camaro or Vette) From the aluminum heads. SS impala has cast heads.
2003 Suburban
1981 Corvette
Old 11-04-2006, 11:35 PM   #8
skchevota
skchevota's Avatar
Bob
Yea what he said, and it will run fine, I did not hook any of that usless smog crap up on mine and it ran great, and it still runs great in my buddys nova. I made a plate to cover the EGR hole so I could remove the valve as well.It will log a trouble code but will not send it into limp mode( at least not on a 95.
skchevota is offline   Reply With Quote
Old 11-05-2006, 12:46 AM   #9
Kenneth_CS87
Thanks for the help.
Old 11-05-2006, 12:51 AM   #10
Kenneth_CS87
how did you block off all the stuff? any pics?.In pics #2 the evaps is connected to the throttle body, do I just block off the hole?
