Old 11-04-2006, 11:12 AM   #1
smills78gmc
How much fluid Turbo 350
How much trany fluid does turbo 350 hold?
smills78gmc is offline   Reply With Quote
Old 11-04-2006, 12:03 PM   #2
boatpuller
boatpuller's Avatar
Re: How much fluid Turbo 350
if i remember right it's about 11qts empty counting the converter being empty.if you just dropped pan and changed fluid.you only get rid of about half that.
boatpuller is offline   Reply With Quote
Old 11-04-2006, 01:37 PM   #3
smills78gmc
Thanks, its on a fresh rebuild, I need to get some more fluid
Old 11-04-2006, 05:58 PM   #4
72C203503ONTHETREE
72C203503ONTHETREE's Avatar
Dont forget to put a couple quarts in the convertor before putting it back on. Also, dont put all 10 qaurts in the trans at once, you will have a mess from fluid overflow. Put about 5 in first(with the trans in the truck and with the driveshaft in) start it up for a few seconds then check the fluid level. If theres no fluid on the stick then put the total amount of 10 quarts in to make sure it doesnt get overfilled, then recheck the fluid normally and top off.
72 Chevy C20, SOLD (Dang it.)
09 Challanger RT six speed in all black.
74 Datsun 710 wagon, all 1.8 liters of screaming Datsun power.
73 C10 long bed, 350/350 combo, nice shape.
72C203503ONTHETREE is offline   Reply With Quote
Old 11-04-2006, 06:04 PM   #5
piecesparts
Parts and more parts
piecesparts's Avatar
Is this like how much wood would a woodchuck chuck if a woodchuck could chuck wood?
piecesparts is offline   Reply With Quote
