Old 11-04-2006, 04:38 PM   #1
pimperout
pimperout's Avatar
fuel pump
this is the fuel pump for a 70 GMC 350 2wd truck right just wanna make sure befor i go and take it off my fuel pump is going but im not sure where it is thanks
pimperout is offline   Reply With Quote
Old 11-04-2006, 04:45 PM   #2
Werewolf
Woof?
Werewolf's Avatar
Re: fuel pump
Looks like it, yes. It's on the passenger's side, front of the block, way down low near the timing cover, just above the oil pan.
1968 LWB CST BB
2004 Avalanche Z71 LT3.
2003 S-10 ZR2 (hers).
1997 Astro
1992 Caprice wagon, 500k stock miles. Nursing wounds after a bad wreck.
1997 Saturn - need gas mileage from something!
Werewolf is offline   Reply With Quote
Old 11-04-2006, 06:40 PM   #3
msgross
msgross's Avatar
Re: fuel pump
here is a pic I took for someone else. See the bolt to the right of the pump? it's in the front of the block. Remove it and insert a longer bolt to hold the pushrod from the cam in the up position. If you don't then it is a pain in the a$$ to put the new fuel pump on and tighten it down.
msgross is offline   Reply With Quote
Old 11-04-2006, 08:40 PM   #4
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
Re: fuel pump
to hold the push rod up it take my oil dip stick and put the smart end in the port holding the rod back and bend the dumb end over and wedge it against the fender well. its thin enough to fit the pump in with it in place but stiff enough to hold the rod back.
trkklr77 is offline   Reply With Quote
Old 11-06-2006, 02:24 AM   #5
pimperout
pimperout's Avatar
Re: fuel pump
ok thanks for the help guys
Old 01-20-2007, 09:26 PM   #6
67cst
i love summertime
67cst's Avatar
Re: fuel pump
is there a specific torque when putting the pump back on or do you just snug everything up? also do you guys silicone everything up or just use the gaskets?
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 01-21-2007, 01:49 AM   #7
PumiceMan
Junior Member
PumiceMan's Avatar
Re: fuel pump
I've never used silicone on the fuel pumps before, so I don't know how well it would work. I've been a big fan of Edelbrock's Gasgacinch, and usually use it on the fuel pump and the water pump gaskets. I would think Permatex would probably work well too.
As for torque, my engine book lists 7-9 ft pounds for the two small bolts on the pump plate, and 30 ft pounds for the two larger bolts (the ones that actually go through the pump). I've always snugged mine up by hand without a torque wrench and haven't had any problems.
If you do use the long bolt method in the front of the block to hold the pump shaft, then only tighten it by hand, or at least be careful not to damage the pump shaft. And don't forget to replace with the right length bolt (with a little silicone on clean threads) when you're all done, or the engine may leak oil there.
Good luck!
I edited this post to add the following:
My truck originally came with a 307. When I swapped in a 350, and used a new fuel pump for a 350, I found that the hard fuel line from the pump to the carb would no longer fit. IIRC, the 307 fuel pump was made for a 5/16" line, and the 350 fuel pump had a larger fitting for a 3/8" line. You could check yours before you go through the trouble of pulling off the old one just to make sure it's got the right size fitting.
69 GMC Sierra 1500 Custom
68 Camaro SS
18 GMC Sierra SLT
Living the dream
Last edited by PumiceMan; 01-21-2007 at 01:53 AM. Reason: Something I forgot to mention
PumiceMan is offline   Reply With Quote
Old 01-21-2007, 02:07 AM   #8
rage'nrat638
rage'nrat638's Avatar
Re: fuel pump
heres the fuel line i bent my self and reflared with my double end flaring kit..
i was proud of this bady...one try
i just went to auto zone and got the new 4 ft 3/8' line and went to it
rage'nrat638 is offline   Reply With Quote
Old 01-21-2007, 02:12 AM   #9
Jtrux
I'm a poor spectator
Jtrux's Avatar
Re: fuel pump
There's not a lot of oil pressure in that area of the block so I wouldn't worry about slathering on the silicone. Personally I use a little bit to just hold the gasket in place. Also before installing it pack the pump with some grease and I usually pull the push rod and put a coat of grease on that too although you really don't have to do that but I ALWAYS pack the pump housing with grease prior to installing it.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 01-21-2007, 10:22 AM   #10
piecesparts
Parts and more parts
piecesparts's Avatar
Re: fuel pump
I always put a little Permatex Aviation gasket sealer on the gasket, to ensure that there is no seepage around the gasket. I then use a thick feeler gauge to hold the rod up and start my fuel pump rocker under it, after that it is in the process for tightening the bolts evenly,Tightening to 7 to 9 pounds torque is about the same as a snugged up with a short ratchet, never did more than that.
piecesparts is offline   Reply With Quote
Old 01-21-2007, 02:30 PM   #11
67cst
i love summertime
67cst's Avatar
Re: fuel pump
thanks guys
