11-04-2006, 09:38 PM | #1 |
installing a corvette steering wheel?
Hello All,
New to the board. I've got a 69 GMC(396,22k) and I'd like to install a '69 Vette wood wheel. When I tried to use the vette hub, it was binding and the turn sigs wouldn't cancel. What hub do I need in order to use this wheel? Thanks. (I tried the search but didn't have any luck) |
11-04-2006, 10:17 PM | #2 |
Re: installing a corvette steering wheel?
All I know is I put one on my 72 and used the same hub as a 69 Camaro uses.
70 CST Bunch of old Camaros |
11-04-2006, 11:28 PM | #3 |
I was told to use a 67-68 camaro hub as they are a little smaller than the later ones and should match the truck steering column diameter a little better. Z10kl does your hub seem a little larger in diameter than the steering column??
"You can take the man out of PA, but you can't take PA out of the man" |
11-05-2006, 12:14 AM | #4 |
I believe the newer hub is just a little larger in diameter - maybe 1/4th inch at most. It is hardly noticeable when installed. It is also not quite as tall as the early hub. I know some of those early wood wheels are dished quite abit. That combined with the taller early hub could crowd the wheel closer than stock.
I bought a reproduction early hub and had some difficulty getting it close to the collar. It did not fit nearly as close as the newer hub. I have not played with it yet to make it fit better. Describe your problem a little more in detail.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
11-05-2006, 01:44 AM | #5 |
[QUOTE=.
Describe your problem a little more in detail.[/QUOTE] Thanks for the reply. I tried to use the Corvette hub with the Corvette wheel on my truck. It went on OK, but when I tightened up the nut, it began to bind. The wheel would turn(with a little effort and you could feel it rubbing), but it wouldn't return to center due to binding and the signals wouldn't cancel.
69 GMC, 396,ac 22k and a hanger full of muscle and sports cars. |
11-05-2006, 04:51 AM | #6 |
68 C10 Longbed
I put a wood wheel on mine using the kit that comes with the wheel and it works fine. My problem is I can't get the horn to work!
11-05-2006, 06:44 AM | #7 | |
have you tried pushing the steeringwheel down while pressing the hornbutton if it does work then you need to tighten the hub up a little more
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
11-05-2006, 10:30 AM | #8 |
12 - Sounds like the hub goes on too far. Pull the hub and see if you can see where it is rubbing. What horn contact/cancel cam are you using? Should be the one for your column. What column - tilt or non?
11-05-2006, 10:51 AM | #9 |
The LuvShack Garage
I think that's what is on GQ according to the PO
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
11-05-2006, 12:14 PM | #10 | |
I'm using the stock(truck) contact/cancel with a non tilt column. I think it does either gone on too far or the inner diameter of the hub is a bit small for the column. You guys have given me an idea though. I've got an extra hub for my 72 GS455 with sport wheel. Maybe I'll give this hub a shot with the 'Vette wheel.
11-05-2006, 08:36 PM | #11 |
I ended up using my truck contact ring instead of the Camaro one because the truck one was tapered to seat the upper column bearing.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
11-05-2006, 11:15 PM | #12 |
12 - Any better luck with the different hub?
