Old 11-04-2006, 10:11 PM   #1
Texasdeere
Texasdeere's Avatar
What is this part? BB402
1972 C10 402
What does this little valve do? It seems to be plugged up so I installed a push in breather there for now.
Texasdeere is offline   Reply With Quote
Old 11-04-2006, 10:14 PM   #2
woodridge
woodridge's Avatar
Re: What is this part? BB402
PVC flame arresster (sp?) or bug catcher if the air filter gets left out
SEMA Network- Protect our Hobby!
71 C30 in pieces, starting to come together.
Click here for A Place For Tennessee Truck Enthusiest To Meet
woodridge is offline   Reply With Quote
Old 11-04-2006, 10:22 PM   #3
Texasdeere
Texasdeere's Avatar
The PCV valve is clear and working good, but there was so much vacuum inside the engine it whistled unless I pulled up the dipstick a little or removed the oil fill cap.
Old 11-04-2006, 10:46 PM   #4
longhorn70gmc
longhorn70gmc's Avatar
Hi TexisC10,
It looks like your missing the same bracket I am. It mounts to the back of the A/C Compressor and mounts to the Engine intake Manifold on the passenger side of the motor. It goes across the top of the valve cover.
Respectfully
Billy
1970 GMC Sierra Grande 402/TH400
(Longhorn)14 years and counting rebuild!
1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches
1970 Ford F250 Ranger 390 BB
2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires
Hub Cap Freak!
I need another truck like I need another hole in the head!
I'M IN THE MARKET...AS IT WERE!
longhorn70gmc is offline   Reply With Quote
Old 11-05-2006, 12:17 AM   #5
da-burb
"Ochre Ogre"
da-burb's Avatar
Flame arrester is the correct answer. If your carb were to back fire, the screen inside this would stop the flame from ignighting any oil or fumes inside your engine. You should be able to soak it in solvent and blow it clean.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
