Old 11-05-2006, 02:07 AM   #1
Johnny05
Johnny05's Avatar
83 GMC ignition
I figured I'd post this here to get some ideas... A friend of mine is giving me an '83 GMC short bed with a 305 and it only has 53,000 original miles! At the moment the truck isn't running but it was ok about a month ago
The problem is that it has no spark at the plugs. I've gone through the distributer completely so it's all new inside and out as well as new wires.. I checked the input side and there is power going into the distributer so my question is why nothing out?? I found out tonight that it has a Electronic Spark Control module under the dash behind the glove box. Could this be the culprit?? I hate to keep throwing $$ at it and not getting any results and the ESC module is pricey but available. Any help I can get from you guys would be GREAT! Surely I'm not the only one to ever have this happen..
Johnny05 is offline   Reply With Quote
Old 11-05-2006, 08:15 AM   #2
hiway
Mad Scientist
Re: 83 GMC ignition
Get a module from an earlier HEI (pre 81) and do away with the ESC stuff. Should cost ya less that $20 to convert.
Everythang relates to Beer!
86 1/2ton on tons! sbc/465/208/D60/14/35's
81 Postal....with 468 bbc
97 Merc Marq comuter
07 Suburban
02 Danger Ranger
hiway is offline   Reply With Quote
Old 11-05-2006, 10:47 AM   #3
Johnny05
Johnny05's Avatar
Re: 83 GMC ignition
Is the pre '81 module plug and play? What else would I need to do? The module that's in it now is a 5 blade style the earlier is a 4 blade. Will this changeover take care of the problem that I'm currently seeing? For as long as I've been working on automotive projects this has to be one of the most puzzling to me.... Maybe I'm just getting old..
Old 11-05-2006, 11:40 AM   #4
ProStreet83C10
Drag Racer
ProStreet83C10's Avatar
Re: 83 GMC ignition
ya beat me to it!
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
ProStreet83C10 is offline   Reply With Quote
Old 11-05-2006, 12:01 PM   #5
us111
Re: 83 GMC ignition
more than likely thats your problem..no spark that's usually the reason on those..
us111 is offline   Reply With Quote
Old 11-05-2006, 12:11 PM   #6
Johnny05
Johnny05's Avatar
Re: 83 GMC ignition
Thanks to everyone for the reply's! After doing a few different searches here I may be able to "check" it. Appparently I can use a jumper in the existing setup and bypass the ESC. I'll try that as soon as I can get back out to where the truck is. If there's aomething else I need to try please let me know.
