Old 11-05-2006, 02:22 PM   #1
Eroc007
1962 drop and discs
I'm new to the board here and i have a not-so-original question. I can see it has been discussed here before but i cannot find anything specifically for 60-62.
I'm looking for the best way to drop the front and rear and possibly switch to disc brakes in the front at the same time. I don't want to spend a fortune and from what i understand later model chevy truck crossmembers will bolt up, but not sure if that is the way to go vs. a disc brake kit and drop spindles.
If the later model is the way to go can somone give me specifics on donor truck and tips on the mod? I see from the sticky that the crossmember can be left untouched. If i want to get a healthy drop do i need to use drop spindles on the later truck suspension?
Eroc007 is offline   Reply With Quote
Old 11-05-2006, 02:31 PM   #2
Eroc007
Re: 1962 drop and discs
Sorry, just introduced myself over in the welcome forum. I am bad at following directions...
Old 11-05-2006, 03:09 PM   #3
kyle4381
You have torsion bar front suspension. Just loosen the torsion bolts and it will drop about 3" or so. As for the discs just swap in new spindles. Many companies sell kits..
kyle4381 is offline   Reply With Quote
Old 11-05-2006, 04:19 PM   #4
Frizzle Fry
Frizzle Fry's Avatar
I'd go this route and get drop springs/spindles http://67-72chevytrucks.com/vboard/s...d.php?t=171667
Frizzle Fry is offline   Reply With Quote
Old 11-05-2006, 08:04 PM   #5
slepysal
slepysal's Avatar
iI thought the A arms were diferent on 60-62 ?
slepysal is offline   Reply With Quote
Old 11-06-2006, 07:25 AM   #6
Eroc007
Yes they are, that's why i'm looking for the best method for 60-62....
Old 11-06-2006, 12:42 PM   #7
kyle4381
Unless you are planning on installing air ride I would stick with the factory torsion bars. Once it is lowered down they handle nice. I think the frames for 60-62 were ahead of the times. They are boxed in from the factory and use torsion bar front suspension.After you loosen the torsion bars, install a nice sway bar.
Old 11-07-2006, 06:48 PM   #8
Eroc007
Thank you. and if i want to get it lower than the 3" inches it has already dropped, it looks like i can do a drop spindle (with disc brake kit). Any problems with that that you know of?
Old 11-07-2006, 10:35 PM   #9
Pritchard1970
I have a 62 truck as well and went with the air bags with a complete front crossmember and control arm set up from a 1976 truck.....overall the process has gone very smoothly...I've got pics if interested and if you have any questions
Pritchard1970 is offline   Reply With Quote
Old 11-07-2006, 11:03 PM   #10
slepysal
slepysal's Avatar
pics would be great !!
Old 11-08-2006, 01:03 AM   #11
Slowmotion
I built my last 61 just as Kyle4381 said and loved the ride. On my current 61 I am using CPP dropped spindles, and disks. This setup works for me.
Slowmotion is offline   Reply With Quote
Old 11-08-2006, 03:18 AM   #12
Frizzle Fry
Ya your right. I'd do the whole xmember swap. Gives you more options in the future.
Old 11-08-2006, 04:25 PM   #13
62ChevyStep
62ChevyStep's Avatar
As I have stated else where on this forum, I would have to agree (just my .02)
________________________
62' 3.5/5 drop SWB Fleet, PS, PB-Dsk/Drm,350/700R4
08' Chevrolet Silverado CrewCab
05'Toyota Tacoma Prerunner SR5
62ChevyStep is offline   Reply With Quote
Old 11-08-2006, 06:07 PM   #14
Eroc007
Do you have any pics that show the new stance?
Old 11-08-2006, 06:09 PM   #15
Eroc007
That reply was aimed at Slowmotion (torsion bars with CPP drop spindles and discs). I'd like to see the new stance if you've got photos.
Old 11-08-2006, 06:47 PM   #16
Pritchard1970
Here is some current pics of the air bag set up.....once I confirm there is no problems I will be taking everything apart for a final sanding and paint before reassemble......Does anybody know the best place/$ to pic up the REZ power steering bracket....I am out here in CA.....thanks
Old 11-09-2006, 11:49 AM   #17
62ChevyStep
Since this topic is a regular on this forum and will be as long as there are pre-63-87 IFS trucks and owners looking to upgrade I came across this article:
http://www.chevytrucks.org/tech/1963...%20UPGRADE.htm
I know it shows it for 47-55 year trucks but in some respects is 98% applicable to 60-62 also.
Hope it helps
Old 11-09-2006, 06:20 PM   #18
Eroc007
Great link! Is there an ideal year for donor truck? I'm sure quality suffered somewhere between 63-87.
On the torsion bar method, I'm still looking for some pictures of slomotion's ride to see the stance.
Can anyone else comment on the virtues of the torsion bar front end ride quality? I hate to throw out the old and bring in the new unless it's useless (or maybe i'm just getting old).
Old 11-11-2006, 03:36 AM   #19
Slowmotion
Eroc I sent you a pm that will direct you to pics.
Old 11-12-2006, 08:32 PM   #20
zenish
73 -87 are the good ones.
1964 c10 short step
1962 econoline van
1989 rs camaro
2006 yamaha vino 125
1975 goldwing
zenish is offline   Reply With Quote
Old 11-13-2006, 11:15 AM   #21
GR82BME
GR82BME's Avatar
As you can see from my pic that the front end is to high, just this weekend i loosened the torsion bar and droped it 2.5 inches and i looks great and rides just fine
GR82BME is offline   Reply With Quote
