Old 11-05-2006, 05:55 PM   #1
chevy garage
chevy garage's Avatar
Tilt Column Problem
I'm putting a van tilt in my 70 C-10. I've mounted the column in the truck but now the shifter will not go from Park to Low all the time. It only travels from neutral to low position. It did this when I first bought it at a swap meet, but I thought it was the wiring for the turn signal switch. I moved the wires around and it worked. Now it's doing it again and i can't figure out why.Any idea what this could be?
Mark
chevy garage is offline   Reply With Quote
Old 11-05-2006, 08:19 PM   #2
chevy garage
Re: Tilt Column Problem
Ttt
Old 11-05-2006, 11:23 PM   #3
Bob Moore
Sounds like something is binding inside. Possibly a part of a broken pointer. Take the column out and remove the steering wheel. Use a light and probe for obstructions. If it shifts out the truck then the problem is in the linkage.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 11-05-2006, 11:33 PM   #4
chevy garage
It was doing it out of the truck too. Could part of the pointer be broken down inside the column housing?
Old 11-05-2006, 11:53 PM   #5
396 SS
396 SS's Avatar
Yes you have a piece of the pointer broke off
396 SS is offline   Reply With Quote
Old 11-06-2006, 01:44 AM   #6
Aarons72s
HAd that problem on mine back in the 70's. You probably have a peice of the pointer. Ours broke in the orange and white and had to go inside to remove it. If I was you i would not reinstal the pointer. Mine has been missing since the mid 70's. i just use the mount for a pointer.
Aaron
Aarons72s is offline   Reply With Quote
Old 11-06-2006, 09:33 AM   #7
chevy garage
Thanks everyone, I'll try to get the broken piece out tonight.
Mark
Old 11-06-2006, 11:44 AM   #8
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
This may help you
sneakysnake is offline   Reply With Quote
Old 11-06-2006, 07:43 PM   #9
chevy garage
Problem is fixed. I really appreciate you all helping me out on that. I was stumped.
Thanks Again
Mark
Old 11-06-2006, 07:44 PM   #10
Bob Moore
What was the problem?
vac, 454, T400
more to follow
Old 11-06-2006, 07:51 PM   #11
chevy garage
Pointer was broken off. I heated a stiff wire and pulled out the piece. Now it works like a dream.
