Old 11-05-2006, 07:35 PM   #1
71elect
What to watch out for when looking for 69-72 4x4 Blazers / Jimmys
Hello everyone!
I've started watching for the 69-72 4x4 Blazer \ Jimmys that are for sale once in a while in my area and i've determined that I need some advice on what to be aware of. I've owned the 2wd & 4wd pickups but never a Blazer \ Jimmy. What problem areas should a guy be watching out for when out searching for a 69-72 4x4 rig? I've found on this forum that there are 2 types of hard tops (single wall & double wall), how do ya tell the difference & which is more desireable? Any problem areas on the fiberglass tops that need to be watched out for? What about the doors, any way to tell if it's a hacked down pickup door? Are the windseild frames prone to rust out easily? What areas of the tub need to be watched for rust? Roll bars, did they come from the factory as an option or standard equipment?
Sorry for all the questions, but I would rather have knowledge up front to know when to buy & when to walk away.
Any advice you can give will be greatly appreciated,
Thanks,
Josh
72Chevy swb 4x4
71GMC swb 2x4
71elect is offline   Reply With Quote
Old 11-05-2006, 09:01 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: What to watch out for when looking for 69-72 4x4 Blazers / Jimmys
Rockerboxes, Windsheild Frame, Firewall are 3 pretty major ones
*Doors are the same as P/U's, just have to cut them down to fit.
*Single walls are more desireable, they bolt from the top down &
have dome lights in them, value of them is 3x that of the double.
*Roll bars where optional, the OE looking ones are harder to find.
Hope this helps as I'm sure others will respond with much more
Owner/Op: "TN Classic Transport Carriers"
Daily Driver: "HerNameIsRio" 68 GMC SWB
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Toy Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 11-06-2006, 07:25 AM   #3
vtblazer
vtblazer's Avatar
Areas to find rust are:
*Torsion boxes, qiute often missing all together.
*Rockers, both inner and outer.
*Kick panels, pretty much always find some there.
*Floors, depends on the life they were treated to.
*Rear bed sills, yep look there also.
*Wheel wells, same story.
**Windshield frame** < nuff said, make sure to check 'em.
*Firewall behind brake booster.
*Cowl, can't really see it until you remove the fenders.
*Lower door pillars both front and rear.
Blazers/Jimmy's have an uncanny nack of hiding the rust, so if you do find rust and you will, it's typically only the beginning.
Take your time and find a nice one, it'll be well worth it in the end.
They seem to be all over out west, be prepared to make a road trip for the
right one.
Good luck and welcome to the board, enjoy the ride.
vtblazer is offline   Reply With Quote
Old 11-06-2006, 12:21 PM   #4
jhow66
jhow66's Avatar
Biggest thing to look out for is --aww it will not take "much" to fix it.
Define "much" as meaning $$$$$$$$$$$$$$$$$$. Ask How I know this.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 11-07-2006, 12:17 AM   #5
71elect
Thanks guys!
I had an idea where to look for rust on the pickups, but that blazer tub looks like it can hide a few spots i'm not used to looking in. Any areas that are prone to cracking or should be watched out for on the shell? I guess we do have it a little better out here in the west as far as rust goes. Still I've come across some nasty flaky swiss cheese metal out here.
Thanks again guys for all the advice,
Josh
72Chevy swb 4x4
71GMC swb 2x4
Old 11-07-2006, 04:16 PM   #6
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
or "It's basically finished, just add paint"
Old 11-07-2006, 06:25 PM   #7
jaros44sr
jaros44sr's Avatar
Check and make sure the steering box is secure. pretty beefy plate from the factory, but one never knows...
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is online now   Reply With Quote
Old 11-09-2006, 03:37 PM   #8
OLDCHEV4X4
OLDCHEV4X4's Avatar
Check the hatch for cracks around the hinges. They are hard to find, a good one anyway. And the top around the hinges too. My top had a roof rack added to it and now has holes in it. The rear hatch handle area cracks out too. Good luck!
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
