The Hammer Man
![]() Join Date: Oct 2006
Lifts? drive on type or frame lift type?
In preperation of my re-store, i'm looking into lifts. I can't seem to decide if i want the type you drive up on and then press a button and it lifts the truck or the kind that you drive under and slide the arms underneath the truck and lift away. This seems like a simple decision but if one is going to do a complete body off resto which works the best for all one has to do? And finally is there a brand that stands above the rest? I'm looking ebay to get ideas but eventually would contact the manufacturer directly to order.
Is there rule of thumb so to speak on deciding on a lift. some tell me i need at least 4" concrete and i really dont know what the hell i have in my building but no issue there. so to lift by the wheels or lift by the frame thats the question? when i watch shows like TRUCKS he has both, i dont have room for both nor the desire.
Boise69. Bought in Boise ID and its a '69 ___________________________________________ 1969 Chevy C-10 SWB 350/400 - drivable project www.americanhammer.com 2013 MBZ Sprinter customized 2005 MBZ Sprinter Van 2004 Land Rover Discovery 2001 Yamaha Road Star 1997 MBZ E420 1989 Ferrari Mondial T |
The LuvShack Garage
Re: Lifts? drive on type or frame lift type?
Where I used to work at PT on the side, they had both kinds, the 2 post
takes ALOT less space, it really depends on what you like / have space 4
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
The Hammer Man
well it will be in the corner and the bad thing is i will have to turn the truck around so i can get to the other side. haven't worked out the details of that yet but in the sake of space the corner is an obvious choice. we'll see.
The Older Generation
I bought a two post hoist from AutoLifters. Like you I shopped, studied, asked, and procrastinated. I think the four post may be a little more convienient as far as getting the vehicle up in the air and not being so picky about concrete thickness but I personally think the two post is more versatile. I used mine to raise my cab up and rolled the frame right under it. I also made adapters so i can lift my lawn tractors up & have clear work area under them. Best pennies I ever spent.....
![]() One of the drawbacks is that this lift required 6" thick concrete. LockDoc
A 4 post takes up more space and limits what you can do. I have both and the drive on gets used very little.
SEMA Network- Protect our Hobby! 71 C30 in pieces, starting to come together. Click here for A Place For Tennessee Truck Enthusiest To Meet |
2 post best way to go. on a 4 post its hard to take the wheels off and work around those areas if you dont have the jacks for them.
2 post is the only way to go in my opinion you can,t even change a tire on a drive on without rejacking. i don't even have a clue what a drive on would be good for other than an alignment rack with the cross bracing in the way under the vehicle
common sense isn't so common anymore |
If I had the space for a lift, I would save my pennies for a Rotary SmartLift. These things make for a clean look. They are easy to service too.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
More pics of the lift in action.
The Hammer Man
HEY ONDREW... calling ONDREW your profile says you do concrete work, how about the pics above, can you do that kind of concrete worK??
Questionable
My friend/coworker Chuck Higgins had his garage featured in the "Ultimate Garages" book. My other friend Craig is looking at putting a lift in his garage. This is what Chuck had to offer when I was pinging him about his lift:
shifty: Just want a couple answers: 2 post or 4 post? What make/model? Cost? Any complaints? shifty: I'm curious to know if you installed it or paid someone else to do it. If you installed it, wondering how hard it was. Chuck: I have the 'Rotary' brand 7000lb lift (2 post, asymetrical). it has been FLAWLESS, I highly recommend them Chuck: I had it installed, but after watching the 70 year old guy they sent install it, anybody could do it. Chuck: the trick was to use an engine hoist to stand up the verticals, then it all bolts together Chuck: I think it was right around $2500 - a little expensive but worth every penny, and built like it will last a lifetime shifty: that doesn't sound at all expensive. how is it put into the ground? Is it bolted to the floor? curious about the install. the thought of what that thing is going to hold up ... that's a lot of weight and i wouldn't want to play with a car over my head Chuck: it needs a lot of vertical space, it's like 10' high... Chuck: it's bolted to the slab with expansion bolts - the weight of the car ends up pretty close to balanced, so it doesn't want to lean that much... Chuck: I made my slab thicker where it bolts, but Rotary said it's not necessary to do that. Chuck: the feet to the supports have laser cut slots in them to allow them to be precisely aligned with each other... it's like 7 or 8 feet across though, plenty wide... look up rotarys 7k lift it should have details. shifty: cool, thanks again Chuck: NP. btw, Rotary makes a 9k lift, BUT the arms on this are bigger, so you can't put lowered cars on them easy. Not sure if this tidbit of info helps, but it IS related, so I am sharing.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
The Hammer Man
wow, yes i would say it helps! i thought it went into the floor, but not so? so if i ever sold my building and moved it would unbolt and could take it with? I'll check out their site and read up. thanks very much!!
#13 |
Questionable
The 7k Rotary as mentioned in mine just uses 4 toggle bolts on each leg, if I remember looking at Chuck's correctly, so you could absolutely take it out of the floor and move it.
It looks like the really cool discreet one that is a couple posts up actually goes into the floor though.
#14 | |
![]() Join Date: Mar 2004
Speaking from someone who has both: A two-post lift is what you’re going to want. In addition to raising your entire truck you will find it useful for lifting virtually anything off of your truck. Bed cab exc. now granted I wouldn't use it to pull an engine unless it was on a unibody car "out the bottom" but I have used it too hold up project pieces while grinding and welding. I’ve also used it to flip my frame over and to put it on a rotisserie. In addition, if you’re pulling axles or cross members it's far safer to do it on a 2 post. Ok so to further explain why a 2 post is so much better it's all about access. When it's down all you have to contend with is the arms that stick out when up virtually everything is accessible whereas with a 4 post the floor space is virtually wasted when the lift is not in use. As for the concrete there is an easy way to check its depth. Barrow a hammer drill and drill a 1/2in hole in the floor close to where you're planning on putting the lift. Drill until you don't feel resistance. Don’t push too hard or you may not be able to tell the depth. When you feel the change stop drilling, clean around the hole with the bit still in it and mark the bit with tape or a permeate marker and pull it out. Measure the distance from the bottom of the bit to the mark you made. This is the depth of your concrete. Fill the hole with mortar, epoxy, or gummy bears it's your choice. If all else fails and the concrete is too thin, let me know "I’m a concrete guy" and I’ll come in and redo it with 5/8's rebar, 10 guage wire mesh, and a trowel finish for a reasonable price. |
#15 |
Oilfield Trash
I'll be buying a 2 post lift for sure when i build my garage
14 Dodge 3500 Mega Cab 08 Dodge 3500 Mega Cab 87 Chev 3+3 4x4 80 GMC K10 High Sierra bone stock 70 Chevelle 350SS long term project 68 GMC 3ton Grain Truck/Garbage wagon 50 Pontiac 2 Door Coupe Project "I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr. |
#16 |
The Hammer Man
can i say... ondrew i'm glad i met ya!
#17 |
Rottenwood Garage Member
Here is a generic picture of what I have........not ideal for brake jobs but I use them for my bigger trucks also. For a back yard shop with limited space.....a 2 post is the way to go !!!!!!!
#18 |
Im going with a Vangaurd VTP-11c Its a 11K two poster. Remember with a 2 post lift you get a lot more underside room to work and not as much stability. So take a look at the biggest vehicle your going to put on it and make your decision based on that, being the front and back weight distribution. Good luck with you decision.
JRB |
#19 |
![]() Join Date: May 2005
I bought a two post Rotary aysmetrical about 18 months ago and have found nothing that comes near it for use, and strength. I got it from an auction of a k-mart that was going out of business for the tidy sum of $800.00 and without a doubt the best money I have ever spent, if fact my first thought was "I should have bought this 20 years ago." Rotary is top notch and if you look through the business auctions you may find one fairly cheap!........Joe..................Never pay list!
#20 |
Chief Honcho In Charge
Harbor Freight has one
http://www.harborfreight.com/cpi/cta...emnumber=46604 Not sure of its usefulness...just saw a pic of it in their store ysterday.
1992 1500 4x4 Shortbed 1984 Ford F250 Supercab Longbed 6.9L Diesel 1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C 1971 VW SuperBeetle 1960 Wife 1984 Son 1986 Son 1989 Son Previous Trucks 1967 C10 SWB (1980-1981) 1971 C10 LWB (1998-2004) |
#21 | |
The Hammer Man
Harbor freight?? If the wrench i buy and the castors i bought along with other things i've purchased from them break within.. ohh... a short time of use then i'm certainly not trusting my head with their lifts!! China freight is just too scary of an option for something this important.
#22 |
I have three rotary 9000 lb'ers. 1 of them aysmetrical. Got rid of a drive on rack because it became a work bench. Never used it.
To bad you're in Illinois. I've got one too many of these lifts. |
#23 |
The Hammer Man
hmmm, Virginia huh? well i have trucks and virginia is a nice place to visit this time of year. sending me a pm on the details please.
#24 |
The info I had said the 4-post lift was OK with a 4" slab, but the 2-post required 6".
#25 |
I have a two post rotary at the shop. I'm thinking of using a four post at the house so it can be moved around.
