Old 11-05-2006, 10:55 PM   #1
shane72_383
shane72_383's Avatar
Polishing Aluminum...
Im looking for somewhat of a how to on how to polish alumium. Im aware that its a pretty involved process and takes time and patience. Im just looking for some info on the general process behind it. Thanks, Shane
shane72_383 is offline   Reply With Quote
Old 11-05-2006, 10:58 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Polishing Aluminum...
What are you trying to polish? Is it rough cast or smooth? Is it a flat surface or peaks and valley's?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-05-2006, 11:10 PM   #3
shane72_383
Edelbrock Performer SBC intake
Old 11-05-2006, 11:54 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Your best bet is to buy one polished. If that's not an option then go to www.eastwood.com and check out their polishing kits. They sell all the pads, roll tips, coumpound, etc to polish it in a kit form.
It will take LOTS of hours for minimal results....
Articles-
"Refining Sierra"
Old 11-06-2006, 12:12 AM   #5
shortbed70
shortbed70's Avatar
you need to first sand off the rough casting with like 120 grit then come back with 200 and then scotch bright the whole thing and see what you have the polish using a high cutting compound working up to the lower buffing compound. Home depot sells the compounds and the kit to grind can be bought from summit and jegs. Yes its alot of work. I just made a overflow tank for my radiator and am in the process of buffing it. I made this from aluminum stock and tigged two ends on it.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
