Old 11-06-2006, 12:15 PM   #1
HotRod73
HotRod73's Avatar
Fuel Gauge Problem?
My fuel gauge seems to be sluggish... when im driving i really cant tell how much gas i have unless i stop. sometimes i can. it just acts slow and fluxuates alot. what would fix this? a new guage? new sending unit? im sure its common on these trucks..
HotRod73 is offline   Reply With Quote
Old 11-06-2006, 12:37 PM   #2
CLASSIC87'
OL BLUU
CLASSIC87''s Avatar
Re: Fuel Gauge Problem?
Yep.. that is pretty common as far as my experiences have been. They normally fluctuate at quick accellation or stopping... in short "ALWAYS". A fix would be nice... but I'm not for sure of one.
CLASSIC87' is offline   Reply With Quote
Old 11-06-2006, 01:31 PM   #3
benoit454
Chris
benoit454's Avatar
I checked the ground wir eon mine, cleaned it's connections and plugged the ground wire back on the stud, and crimped it around it pretty tight. it really helped stop it from jumping so bad. Doesn't jump around alot now.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 11-06-2006, 02:34 PM   #4
hiway
Mad Scientist
:tj: Hey benonit, I see you have a G body...you should check out maliburacing.com if you haven't already. Great guys and info there.
Everythang relates to Beer!
86 1/2ton on tons! sbc/465/208/D60/14/35's
81 Postal....with 468 bbc
97 Merc Marq comuter
07 Suburban
02 Danger Ranger
hiway is offline   Reply With Quote
Old 11-06-2006, 05:13 PM   #5
benoit454
Chris
benoit454's Avatar
lol thanks, I se them mentioned alot on montecarloss.com which I'm on all the time. My monte was my project while we drove the truck, now I'm just about finished except for things I want to do, it's all driveable and xcrap so it's not have to anymore just want to, now it's time to try and fix up the truck which is being a PITA.
thread unjacked LOL.
Also, I changed the dash guage cluster out because I had already changed sending units for temp and oil and they didn't work, plus my fuel guage jumped like crazy, so i changed it, and cleaned that terminal on the unit up, crimped the wire connect onto that terminal good and tight and it didn't jump much at all anymore. I say clean connections and make sure they are almost impossible to move, then see what happens.
Chris
GIT R DONE!!!!!!
