Old 11-06-2006, 01:09 PM   #1
Draggn66
Wrenchin & Sandin!!!
Draggn66's Avatar
Bench Seat Question
I've ripped apart my factory bench seat and ordered new foam. It has the zig zag springs at the bottom. Other than being broke which they are not, how do I tell if they are ok? When driving I sank down pretty far. Had to throw a pillow under me to sit right. Has anyone put a piece of plywood or something between the springs and foam to stiffen it up a bit? Or do you think new foam will take care of it? Any advice would be helpful. Thanks.....
Randy
Shorewood, IL.
My Favorite eBay Searches
My Driver Restore Thread
1971 C10 Longbed
2005 Silverado Shortbed
2005 FXDWG
Draggn66 is offline   Reply With Quote
Old 11-06-2006, 04:38 PM   #2
Draggn66
Draggn66's Avatar
Re: Bench Seat Question
anyone???
Randy
Shorewood, IL.
1971 C10 Longbed
2005 FXDWG
Old 11-06-2006, 04:59 PM   #3
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
This is probably one of those you will have to make an educated guess.Before and after the foam is removed compare the drivers side to the middle or pass side. I imagine they weaken over time and unless they are broken it wiill be hard to judge but if it was pretty squishy before and the pad was so-so then figure the the springs are shot on the drivers side
sneakysnake is offline   Reply With Quote
Old 11-06-2006, 09:31 PM   #4
wibilly
wibilly's Avatar
if it leans it will still lean after a boundle of money if you don't repair the foundation{ springs} do it right and do it once
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 11-06-2006, 09:46 PM   #5
Draggn66
Draggn66's Avatar
Yea that's kinda what I was asking. Other then being broken what were other signs that the springs were bad? Loose? a couple are a little longer but not much. Guess I should just say hell with it and change them all.
Randy
Shorewood, IL.
1971 C10 Longbed
2005 FXDWG
Old 12-02-2010, 05:15 PM   #6
bubbaNcolo
I'm also interested in parts or methods to diagnos and repair defective springs. I too have a sagging seat on drivers side. I proped up springs with a 1x4 piece of wood. Wish there was parts to rebuild the springs to remove the sagging issue.
So another question could you remove the springs and replace that with the solid foam lower that I've seen at LMC truck??
1971 Suburban 3/4 axles needs a lot of rust replaced
bubbaNcolo is offline   Reply With Quote
