11-06-2006, 02:53 PM | #1 |
Questions on first 67/72 project
I'm putting a stepside together out of 2 different trucks. One is a '72 shortbed, and the other is a '67 with an 8 ft stepside. Having never done a project like this before, I've got a few questions. If any of you have personal experiences, I'd love to hear from you.
Problems using the 67 small window cab with the 72 nose? Problems converting an 8ft stepside frame to a 6ft? (or better left alone) Easier to lower a 67 frame or 72, or no difference. I'm sure there'll be more, but this will get my gears turning. Thanks in advance, Tully |
11-06-2006, 03:05 PM | #2 |
Re: Questions on first 67/72 project
Use the short wheel base frame and then put all of your pieces together on that and then get a torch and cut that long wheel base frame to pieces!!!!
11-06-2006, 03:11 PM | #3 |
Let me know where you are and if you want to sell the long stepside bed.
11-06-2006, 03:14 PM | #4 |
Unless the 72 short frame is bent, I'd use it. It will have the more popular 5 on 5 lug pattern and you'll have a much wider choice of rims for your truck. Also, the 72 frame should have disk brakes up front already. You can shorten the other frame and swap the 72 suspension components onto it, but it seems it would be easier to swap cabs and body parts.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
11-06-2006, 03:30 PM | #5 | |
Weekend Warrior
Yeh if you are going to use the Short Wheel Base Bed - then stick with the '72 chassis as it has a disc brake front end and the 5x5" wheel bolt pattern. (If the SWB frame isn't any good - then you can shorten the LWB - there is a great tech article on how to do this, and swap the complete front suspension crossmember and rear end into the '67 shortend frame) it is a little more work than swapping the cabs but can be done. Shouldn't be any problems using the '72 nose on the '67 Cab.
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered |
