Old 04-23-2002, 08:57 PM   #1
jmanz69
Careful, they attack...
jmanz69's Avatar
Post Bellhousing question
I have a cast iron bell for my auto-4spd swap. It's the one made foe our trucks. Question is; Do I have to use that one, or can I use an aluminum one from a different car? If so, what cars are best? Also, any idea where I can get the bracket on the frame for the clutch mounting?
jmanz69 is offline   Reply With Quote
Old 04-23-2002, 09:05 PM   #2
69 longhorn
Post
If you are using a car trans,there are 2 different hole sizes on the truck bell. 67,& prior was 4 11/16 (same as car),or 5 1/8 68 up on the trucks. Shoot a little more info on trans ,ect& Im sure there is a way...69
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 04-23-2002, 09:09 PM   #3
jmanz69
jmanz69's Avatar
Post
69
I have a saginaw 4 spd. was going to use a muncie, but too much $$$. The bell I have now is the one with the big hole, and it all bolts up fine. There is a gap, but it will work, plenty of contact area. Just wanted to try to save some weight if I could. This thing is heavy enough.
Old 04-23-2002, 09:36 PM   #4
69 longhorn
Post
Use a input collar from a 3 spd saginaw(truck,68 on),it will bolt up& give you the proper center...........69
Old 04-23-2002, 09:44 PM   #5
jmanz69
jmanz69's Avatar
Post
Is the 3 spd collar shorter or longer? Just wondering.
Old 04-23-2002, 10:03 PM   #6
69 longhorn
Post
the 3 spd collar is bigger around (truck only) ,to match the bell.......69
