Old 11-06-2006, 08:27 PM   #1
chevythunder33
chevythunder33's Avatar
wheel measurement
Hello guys can ya tell me how to measure your rims to make sure im ordering the right set the truck is 5 lug with nova subframe and believe the rear is a 80's model chevy i wamt to figur out if it's 5.on 4.5 or 5.on 5.5 do you measure from the center of the top stud to the bottom stud center please help you figure all the other work i done on the truck i would know how to do this
chevythunder33 is offline   Reply With Quote
Old 11-06-2006, 11:40 PM   #2
thekid54
Re: wheel measurement
Yes, IIRC you measure from the center of one stud to the center of the stud that is furthest away from that first stud.
thekid54 is offline   Reply With Quote
Old 11-08-2006, 11:04 PM   #3
Slammed '87
Slammed '87's Avatar
Here.....
If you can't rock the roads with your bumpers 1/2" off the ground, you're nowhere near low enough!
Slammed '87 is offline   Reply With Quote
Old 11-09-2006, 10:51 AM   #4
Tony@AirRideTech
Junior Member
As long as they did not change the bolt sircle on that Nova subframe..... I bet that you will find that it is a 5x4 3/4 .
Tony@AirRideTech is offline   Reply With Quote
