11-06-2006, 10:54 PM | #1 |
fuel hose max psi ?
anybody know the max psi of 3/8 rubber fuel line or a fuel line rated at75 psi or more that will hold on a barbed fitting with or without a small hose clamp
common sense isn't so common anymore |
11-06-2006, 11:18 PM | #2 |
Location: vacaville ca, because it as far from indy as i can be
Re: fuel hose max psi ?
there is not f-ing way your going to keepa hose on with no clamp at 75 psi....
the high end braided hose is rated for 125 i belive, but regular soft black line is only like 25-30 psi. |
11-07-2006, 12:26 AM | #3 |
i'm trying to replace a fuel pump with one from another canister i belive the opperating presure is between 56 and 64 psi the factory hose has no clamps but it must have been put on and shrunk with heat or streched and shrinksback to origanil size like some modern plastic plumbing pipes . there has to be somthing that will work. fittings are barbed and i do have room for small hose clamps
