factory oil gague?
If your motor isn't stock and your oil gauge reads H when you hit the gas and comes down to 3/4 when you idle. Can you adjust these things?
Is this normal? ![]() |
Re: factory oil gague?
Oil pressure is a function of how hard the oil pump has to work to push the oil past a given clearance-such as the distance between the bearing surface and the surface of the journal-hense the faster the pump turns the more pressure it takes to force the higher volume of oil past the two surfaces. High speed=high pressure, low speed=lower pressure. Normal.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
Outlandish Trends - FL
mine reads the same thing. It's normal.
-Bret 67 short-fleet sold! |
#4 | |||
Union Electrician
You need to get an 80 lb oil pressure gauge to replace your stock 60 lb. I would assume your motor has a high volume oil pump and that is why it is peggin the gauge.My truck when warming up on fast idle will push 75 lb of pressure until I kick the idle down, but I never peg the gauge.
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
#5 | |
My temp isn't working the oil pegs out the amp gague works but I'd rather a volt one. Vaccum works good. What temp oil Batt gauges fit right in the stock 7 gague bezel? with a little work i mean. Hole size wise i guess i mean. ![]()
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
