Old 11-07-2006, 09:24 PM   #1
my67C10
my67C10's Avatar
how much HP does 67 327 v8 have
anybody know?
my67C10 is offline   Reply With Quote
Old 11-07-2006, 11:09 PM   #2
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
Re: how much HP does 67 327 v8 have
what is the block code?
IvelDesigns is offline   Reply With Quote
Old 11-07-2006, 11:24 PM   #3
Jim_PA
210?
Jim_PA is offline   Reply With Quote
Old 11-07-2006, 11:27 PM   #4
IvelDesigns
look on the back of the block, where the tranny mounts, at the top, on the drivers side, there should be a 6 digit code.
Old 11-08-2006, 02:48 AM   #5
GREASEMONKEY72
GREASEMONKEY72's Avatar
i dont mean to steal the thread but could anybody also tell me the HP of a 72 custom/10 stock 350sb BN: 8970014?????
-steven
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 11-08-2006, 09:04 AM   #6
arkracing
Weekend Warrior
the number on the back of the block where the tranny mounts is a Casting number
Casting #'s won't tell you anything about the horsepower of the motor:
you need the block CODE - on the passenger side of the block above the waterpump mounting hole right on the deck of the block there is a small "PAD" with some #'s on it - and the last 2 or 3 should be letters (ie "CKD" or something to that effect)
-you'll probably have to scrape the grease off it - or if you can get a small piece of sandpaper down there - it will help the letters and numbers show up better.
HP Numbers for '71 (so '72 should be around the same) =
350 cid = 250hp@4600RPM (Gross) and 190hp@4000RPM (Net)
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 11-08-2006, 10:29 AM   #7
dave666693
dave666693's Avatar
Mine is rated at 220 hp
dave666693 is offline   Reply With Quote
Old 11-08-2006, 12:54 PM   #8
67 cst swb
67 cst swb's Avatar
My '67 had a from the factory 327 with 4bbl... coded V1220YH... it had a TH400 behind it with A/C.... it was rated at 220HP...
What are the chances of me finding a 327 block coded V1220YH...>
HEY arkracing... the V1220YH denotes Flint, Dec 20th, Turbo Hydro, A/C... But, is there a veriety of date coded for a truck built early Jan 1967?
I'm looking for a correct 327 block, it's the only OEM component missing on my truck all the rest is original (trans, rearend, A/C, bucket seats) hoping to find correct block so it can be a numbers match truck. Please PM reply...
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 11-09-2006, 12:54 PM   #9
GREASEMONKEY72
the number on my block infront of the head is V0408TFD
-steven
-steven
Alte Seele S.S.
