Old 08-16-2002, 12:33 PM   #1
iluvmy72
Question adding AC to a Burb...How Hard is it?
I want to add AC to a 72 Burb and I am wondering how hard it is to do this......do they make kits for these?......and can I have the dual AC(front and rear) in there?
iluvmy72 is offline   Reply With Quote
Old 08-16-2002, 12:43 PM   #2
da-burb
"Ochre Ogre"
da-burb's Avatar
The only thing stopping you would be MONEY. I plan to add A/C to my next burb. I will be using one of the aftermarket systems to add a/c to the dash. I don't think I will be installing the rear a/c system. Part of it is the cost of the hoses running from the front to the rear. They have to be spendy. I am guessing they will run over $300 alone and I don't know if I would trust the 30 year old ones.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 08-16-2002, 04:58 PM   #3
68 Suburban
68 Suburban's Avatar
Here is an option if you dont go new.
http://67-72chevytrucks.com/vboard/s...ight=underdash
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 08-16-2002, 04:59 PM   #4
68 Suburban
How did they run the lines for the rear A/C? Was there a "T" fitting in the engine compartment?
Old 08-16-2002, 05:06 PM   #5
mt Al
68 Suburban,
That's how mine is, with the T fittings. My engine compartment looks kind of like a rat's nest with all of the T fittings for rear heat and rear air. All of the fittings are back by the passenger side hood hinge.
'72 GMC 1/2T 4x4 1500 Super Custom pickup (current)
past rides were:
'70 Chev 2wd farm truck
'71 GMC 2wd 1/2T 402 nice!
'72 Chev 2wd 1/2T 396
'72 GMC 3/4T 4x4 2500 Super Custom suburban.
Bozeman, Montana
mt Al is offline   Reply With Quote
Old 08-16-2002, 05:18 PM   #6
68 Suburban
mt Al, do they run underneath the vehicle and come up in the back? Where do they come up?
Old 08-16-2002, 05:49 PM   #7
ckhd
ckhd's Avatar
They "T" off there by the heater unit under the hood. From there, they run down under the passenger side, then across to where the fourth door would have been, then up into the missing fourth door area, then under the driver's side back window/over the wheelwell, then up the rear pillar to the evaporator.
The Ts just use hose clamps. I plan on changing that when I redo mine for R-134.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 08-16-2002, 05:55 PM   #8
68 Suburban
Damn, that sounds like a pain if you have to run the hoses!
