11-08-2006, 02:08 AM | #1 |
Spark plug wire looms
which looms are yall running? I want a nice clean look, I have a 350 with Hedman elite headers if it helps.
'67/70 Chevy C/10 '10 2500 Crewcab Duramax 4wd |
11-08-2006, 08:36 AM | #2 |
67-72 Addict!
Re: Spark plug wire looms
I have the blue anodized type that run along the valve covers. They go from 4 wire holders in the rear to 1 in the front. I have an extra chrome set that have never been used I am planning to list for sale on the board soon.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
11-08-2006, 09:00 AM | #3 |
70c10 if you do, let me know. been thinking about those myself. pkj
11-08-2006, 09:03 AM | #4 |
Rottenwood Garage Member
These are what was on this truck when I got it. I need to change the wires to block but i will probably leave the looms.
11-08-2006, 09:04 AM | #5 |
go under the header
11-08-2006, 10:28 AM | #6 |
chevy truck fan
i am running the billit specialtiies plain style. they cover the wire from just at the plug to the rear of the vlv cover. i think they were around $60 i would have to look at the papers again though...
rodstored-72 |
11-08-2006, 03:11 PM | #7 |
11-08-2006, 04:12 PM | #8 |
67-72 Addict!
They look similar to 72 freak's. How would you guys mount the looms under the header when the looms are mounted to the valve cover bolts?
11-08-2006, 04:35 PM | #9 |
11-08-2006, 05:05 PM | #10 |
67-72 Addict!
Oh, ok.
11-08-2006, 05:20 PM | #11 |
11-08-2006, 05:27 PM | #12 |
67-72 Addict!
What supports the wires?. Or do they just stay rigid enough to not flop around?
11-08-2006, 05:36 PM | #13 | |
I made a small flat bracket that points downward, and runs almost along the block, then I neatly used tie wraps to make sort of a wiring harness out of all 4 plug wires on each side, so each wire would only reach the plug it needs to reach and keeps the wires away from the headers -- the group of wires is held to the small bracket by another tie wrap or 2 Simple, effective, appealing, and best of all FREE!!! (except for the tie wraps) |
11-08-2006, 08:02 PM | #14 |
This is BIG news! heat rises too! I'm all over it. That old trick using wire ties to make looms(one inside the other) should keep em together.
4sure |
11-08-2006, 08:09 PM | #15 |
gotta get dam hot in here though maybe some loom
on 1 -4 ? Looks and sounds like a better route to go. Have to see how they run under there.
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD Last edited by 67chevemall; 07-09-2010 at 02:26 PM. |
11-08-2006, 10:20 PM | #16 |
The wires are no closer to the header than they would be if I ran them over the top. Here's a closeup of those areas.
11-08-2006, 10:33 PM | #17 |
Tool Addiction=Money Shortage
I hate to admit it but right now but my wires are just held back from the ramshorns with Zip ties.
11-09-2006, 04:44 AM | #18 |
Mine go under the exh. manifolds. Used stock wire stands. Most venders have them. Got mine from GMC Paul. Keeps wires out of the way.
LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! 1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started. |
11-09-2006, 09:19 AM | #19 |
Most all of my other vehicle have them run under, but then again, since I HATE headers all my other vehicle have exhaust manifolds...... so it is a bit easier to run them.
