Old 11-08-2006, 07:08 PM   #1
BowTieOgre
Noob Blazer owner questions
I just bought a '73 Blazer and im wondering what I should do to get it down a little bit from factory ride height. Since the front end is the same as the '70 that I am used to I will just do drop spindles and 2" springs in the front but im totally lost on what to do with a leaf rear end. Bags arent an option due to the budget. Any suggestions? Also, what size tires can i get away with on 15x8 rallys? Here is a pic.
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 11-08-2006, 11:10 PM   #2
84 400
Sb 400 club
84 400's Avatar
Re: Noob Blazer owner questions
Sounds like you got a nice project there. for the rear a shackel kit would do wonders. also could try removing a leaf. good luck
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 11-08-2006, 11:47 PM   #3
powder2
powder2's Avatar
you can get a flip kit
powder2 is offline   Reply With Quote
Old 11-09-2006, 11:10 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
As you said the front is pretty much the same as your 70. You can go with 2.5" spindles or even 3" spindles. If you go 3" spindles your 15" wheels will rub unless you trim the A-arms.
The rear is totally different than what you are used to. You can do a flip kit which puts your leafs below the axle. If you add a shackle your going to have to mod your fuel filler a bit for clearance.
That's pretty much it...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
