Old 11-08-2006, 07:10 PM   #1
gregbr
Senoir Member
gregbr's Avatar
WTB: Eaton Posi for 12 bolt
I would like to find a Eaton Posi for a 12 bolt truck rear with 3.07 gears. Let me know what you have....rebuilt would be nice. Thanks, Greg
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4"
70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010
70 GMC Restoration Pictures
http://67-72chevytrucks.com/gallery/...00&ppuser=4424
gregbr is offline   Reply With Quote
Old 11-12-2006, 02:53 AM   #2
gregbr
Senoir Member
gregbr's Avatar
Re: WTB: Eaton Posi for 12 bolt
ttt
Old 11-12-2006, 09:10 AM   #3
vtblazer
vtblazer's Avatar
For a 2wd or 4x4?
vtblazer is offline   Reply With Quote
Old 11-13-2006, 03:57 AM   #4
EFI70Blazer
Active Member
EFI70Blazer's Avatar
Are you just in need of the carrier or do you need the whole rear end assembly. I have an eaton 3 series carrier, which would be the one you need for 3.08 gears for a truck 12 bolt. The carrier was taken apart at one time and had the case bead blasted. The clutches are in good shape and are from a low milage truck along with the side and spider gears. The spiders do have a little wear on them, but nothing more than normal. If you want it, i am asking $150 plus shipping. I can remove the other carrier bearing before i send it if you want.
Mike T.
Oregon
70 GMC Jimmy 4x4
70 Camaro LS1 plans in the works
71 RS/SS Camaro numbers matching
86 Chevy Silverado SWB 4x4 (454 merlin heads, 3/4 running gear upgrade, Detroit lockers front and rear)
EFI70Blazer is offline   Reply With Quote
Old 11-15-2006, 10:18 AM   #5
BackWoodsRanch
I have a complete 4wd rear (6-lug) from '72 blazer with 3:08's. Will sell for $125 Also, does anyone know if this will fit a 3:73 gearset?
Steve
BackWoodsRanch is offline   Reply With Quote
Old 11-15-2006, 06:53 PM   #6
gregbr
Senoir Member
gregbr's Avatar
Thanks Guys, But after no replies for 5 days I ordered a new one. Greg
Old 11-18-2006, 11:08 PM   #7
badpeanut
Not a bad nut after all..
badpeanut's Avatar
Originally Posted by BackWoodsRanch View Post
I have a complete 4wd rear (6-lug) from '72 blazer with 3:08's. Will sell for $125.
Steve,
Where are you located? My '71 Blazer needs a complete 3.08 posi rearend.
Wes
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
