11-09-2006, 08:52 AM | #1 |
Need some timing carb help!
I can't get my truck to stop with the ping ping ping pop.....
It runs alright but won't stop detenating. I've never did timing on it myself before and need some help as to what I am looking for on the marks when the light goes off? I have the carb rich because I thought the real lean mix was making it ping but know I think it is the timing but I have no clue now..... Any ideas or tricks to this? Cheers
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
11-09-2006, 09:40 AM | #2 |
Java Mechanic
Re: Need some timing carb help!
Pinging can be caused by a number of things but the most common cause is using too much advance for the fuel grade/compression ratio you normally use.
You want to read the mark that appears on the balancer at the index mark as the strobe hits it. To the left of center is advance and to the right is retard. I don't rememebr the spec right off but I think a fairly stock motor starts about 8 to 10 degrees of initial timing. (Look that up.. it's early and I'm tired!) Your initial timing might be ok and you still have ping. That could be caused by having too large of an advance curve built into the distributor.
Keith 11 Lincoln MKT -- Momma's wagon 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
11-09-2006, 12:55 PM | #3 |
Msgt USAF Ret
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
11-09-2006, 01:17 PM | #4 |
mine is set at 8*BTDC and the dwell is set at 30* or .019 i think my dizzy is also the stock points with external coil hope that helps at all and good luck o and also i run on 89 pump gas
-steven
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
11-12-2006, 07:27 PM | #5 |
thanks for the link that is a big help!
Cheers I get it running someday, it has only been 10 years of waiting
