11-09-2006, 10:28 AM | #1 |
Kickdown cable setup with performer manifold
Since the install of my engine I have never setup the transkickdown cable. Last weekend I broke down and purchased a new edelbrock performer manifold. I have a bracket for the kickdown that attaches via the two rear manifold bolts. But when I have the cable attached to the throttle and I work the throttle the cable seems to bend and bind up. for those of you who have the performer and a th350 what did you use to support your kickdown cable? By the way I have the throttle rod setup...
Thanks in Advance! donovan
78 C10 LWB Super Cheyenne |
11-09-2006, 05:20 PM | #2 |
Re: Kickdown cable setup with performer manifold
TTT... anybody?
tx.
11-09-2006, 07:04 PM | #3 |
GEARHEAD
I'd like to know too. I just ended up cutting the heck out of my original one to get it to fit, but it's not very stable. Probably should check with summit or edelbrock for whats available. It's got to be one of the most common set ups out there.
HG
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
11-09-2006, 07:54 PM | #4 |
I will be 3rd in line, I also need to know.
I have the same setup exactly, with a Q-Jet Carb. Does anyone know what kickdown cable part number is the best to use? 68jimmy, good question, thanks for bring this subject up. |
11-09-2006, 08:02 PM | #5 |
67-72 Addict!
This is not my truck but it may help you guys!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
11-09-2006, 10:23 PM | #6 |
As long as I had a new Edelbrock 1406 carb and performer manifold I looked for other Edelbrock pieces when I put my 383 together.
Somebody on this board said I should get a "throttle rod stud" to work with my throttle rod. I also bought an Edelbrock, adjustable kick-down cable bracket. I used one hole that I think is normally used for a throttle cable to hold my aftermarket cruise control. The square hole is made for the th350 kick-down cable. Sorry it isn't real clear in the pictures. In a 4x4, the engine sits really far back and is hard to get any digi-shots of stuff back there. I hope the pictures help. The kick-down cable was off of a 1971 Monte Carlo that had a 350 engine, 2bbl carb, and a th350. I believe ALL th350 kick-down cables are the same, truck or car. The difference is in the bracket. To adjust the cable, attach it to the carb, lift up the little plastic "gate" right behind where it sits in the bracket, move the carb to WOT, then push the gate down.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
11-12-2006, 07:52 PM | #7 | |
11-12-2006, 08:59 PM | #8 |
Yes, pics please if you got em. Also, if you have a NAPA part # for the Spectre bracket. What kickdown cable are you using?
It must be nice to have those carb secondaries to throttle up! |
