Old 11-09-2006, 01:15 PM   #1
ghetto_superman
ghetto_superman's Avatar
a few questions regarding steering gears and 3/4 ton frames.
ok heres my questions.
ive got a P/S box from a 69/70 3/4ton on my 68 halfton. it steers ok.. but its a slow ratio and i want to quicken it up. a lot. i was wondering- can a guy take just the gears out of say, a camaro box, and put them into our box? that would be pretty sweet.
next question.
is there any difference between actual frames from a halfton 2wd and a 3/4ton 2wd? cause the thing is, ive got 2 swb frames (one will be for sale eventually) and i am planning on stretching my cab a bit..originally i was gonna hack them both up to make one longer one, but i realized it would be RETARDED to sacrifice 2 good swb frames from the world if i could just shorten a lwb one.
so ive GOT a 3/4 ton frame (front cab mounts back anyway) and was wondering if it would be worth it to use that frame, if its actually any stronger, cause id still have to shorten it under the cab, add t-arms, t-arm crossmember, spring pockets, shock mounts.. and attach a front clip.. which would pry be halfton rated anyway. OR should i just find a halfton 2wd lwb frame and go from there??
MAN maybe i just answered my own question..!! any suggestions greatly appreciated though...
ghetto_superman is offline   Reply With Quote
Old 11-09-2006, 01:15 PM   #2
ghetto_superman
Re: a few questions regarding steering gears and 3/4 ton frames.
and sorry for the long post btw.
Old 11-09-2006, 01:36 PM   #3
shaneschevys
Its always something!
shaneschevys's Avatar
The 3/4ton frame is the same as the 1/2 ton frame. Just a few extra braces & the rear cab mount sits lower for the taller rubber cab bushing.
79 p10 stepvan
72 Short Fleetside
72 Suburban
67 GMC One Ton Flatbed
64 Short Fleetside
57 Chevy 2DR Hard Top
57 Chevy 2dr wagon
65 f*** short fleet
63 C 60 Flatbed
Member of the patina club
shaneschevys is offline   Reply With Quote
Old 11-09-2006, 06:13 PM   #4
Bob Moore
Supper - If you are working with 2wd here is one way to go. The 69-72 steering box is about 4 1/2 turns lock to lock. The 73 and up box is about 3 1/2 turns lock to lock. I would recommend the 73+ box.
I have often thought about swapping Camaro/TransAm internals into a truck box. I think an IROC would be the quickest. You would have to tear one down to see if it work.
Keep us posted - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 11-09-2006, 09:42 PM   #5
ghetto_superman
cool. i thought that the frames werent any different strength wise.. so that confirms that- and as far as the steering box, i had considered just using a newer one, but some camaro gears would be the ULTIMATE!
Old 11-14-2006, 11:23 PM   #6
ghetto_superman
*bump* still wondering about the steering box swap...
-1947 3100 -1968 C10 -1970 K20
Old 11-15-2006, 01:34 AM   #7
68shortfleet
You could try calling the Tech hotline for ATSCO remanufacturing. I have done this before. I talked to micheal, 1-800-470-2387 ext. 169. I told him exactly what i already had. Gearbox casting numbers, inlet spline count, lock-to-lock count. Then told him what i wanted. Gave him a day and called him back and he gave me part numbers to go to my local supplier with. Very helpful service.
He probably will not need any of the casting info in your application as it is all stock parts right now.
Please post what you learn
Jason
68shortfleet is offline   Reply With Quote
Old 11-28-2006, 03:06 AM   #8
ghetto_superman
well i got a 73-87 box on my latest parts score so ill pry just go with that.. (sorry that phone number sounds good, but im too lazy to do all that research!!) thanks for all the help tho guys!!
