Old 11-09-2006, 05:23 PM   #1
71chevylowrider
71chevylowrider's Avatar
Anybody running a Demon Carb instead of an edelbrock?
I have an opportunity to pick up a slightly used Demon Road Demon carb, I've had a few tuning issues with my edelbroack 1406, anybody have experience good or bad with the Demon?
71chevylowrider is offline   Reply With Quote
Old 11-09-2006, 06:19 PM   #2
BarryB
BarryB's Avatar
Re: Anybody running a Demon Carb instead of an edelbrock?
Only good , from what I have seen and heard. Plus you have a wide variety of parts and supplies for demon and holley carbs.
Problems out of an Edelbrock?? Personally I hate an Edelbrock. Others swear by them. But not me.
BarryB is offline   Reply With Quote
Old 11-09-2006, 06:29 PM   #3
71chevylowrider
My Edelbrock was on the truck when I bought it, it runs way too rich at idle, but the truck hauls when I punch it, I can't get enough traction under 35MPH other wise I just smoke the rear tire, (I'm working on a posi unit). I've heard good things too, I just don't want to jump on it without some advice/experience from someone who runs one on a 350
Old 11-09-2006, 06:32 PM   #4
johnnywagon
Sofa King. We, Todd, Ed.
johnnywagon's Avatar
I've been selling auto parts & speed parts for 14 years and I can tell ya both are great choices for carburetion. Edelbrocks are good all around street carbs, you just have to be willing to make the effort to tune them properly. Try to track down the Edelbrock "Bible" carb tuning book (Edelbrock #0034) any decent mechanic can tune one with this book. Demons are better for more serious performance, they tune just like Holley's & use most the same parts. One thing to watch for on some older Demons is they had a problem with the air bleed system but its a quick fix with new air bleeds (Demon/Barry Grant #421392) Also I would never install a used carb w/o taking it apart first to make sure theres no junk in the bowls.
~John
71 Blazer One Ton
65 Chevelle Station Wagon x2
59 Belair 2 Door
71 Chevy Open Road Van RV
www.myspace.com/johnnywagon
johnnywagon is offline   Reply With Quote
Old 11-09-2006, 06:37 PM   #5
71chevylowrider
HHHmmmm... decisions decisions, I think the Demon is less then a year old & maybe was used less then 6-8 months on a truk that didn't get drove much, it was an older guy & he didn't like how it idled, his truck does not have the modifications that mine has so maybe it would be fine for me, mine has a very noticeable lope, it's a friend of mines dad, so maybe I'll try it over the weekend & see how I like it, hopefully I won't need anything special to adapt it/hook it up, I have a performer RPM manifold, I read on Edelbrocks website that they don't recommend the 1406 on an RPM manifold, maybe that's my problem? I didn't get whay they don't recommend it.
Old 11-09-2006, 06:51 PM   #6
hotrod40
New Member
hotrod40's Avatar
I had a road demon on a ZZ4 motor, had trouble with the idle circuit but performance was good. Just took a Holley off my '72 GMC, 330HP crate motor because I could not lean it out. I replaced it with an Edelbrok 1406, leaned it two stages at sea level and it runs and idles fairly lean, not a race setup but good daily driver setup. Picked up 3 plus mpg on 500 mile trip. A lot of the guys I talked to at rod runs seem to have a problem with the street-ability of the demon carbs. Who knows ??
hotrod40 is offline   Reply With Quote
Old 11-09-2006, 07:06 PM   #7
LockDoc
The Older Generation
LockDoc's Avatar
I bought a Road Demon Jr. last spring to put on my 350 with an Edlebrock performer and I haven't been able to get it dialed in. I've adjusted the choke and reset the floats many times but it still runs way too rich when I first start the car. Seems to run pretty good on the highway but my tailpipes are pretty black & sooty so I think it's running too rich all the time. I'm not saying it's the carbs fault but if you are looking for something to put on & go it's probably not going to happen with the Demon. I've read the booklet 3 or 4 times but I guess it's just not soaking in. I'm thinking about getting a new Quadrajet and putting on it. I'm tired of jackin' around.....
LockDoc
Leon
Old 11-09-2006, 07:12 PM   #8
johnnywagon
Both are universal carbs so they will perform differently on different displacement engines and diff elevations. Its all about tuning. Its easy for a frustrated mechanic to blame the whole carb, when virtually all the internal parts are tuneable and replaceable. The Demon should bolt right on your Performer RPM. If you're switching from an Edelbrock carb you'll need to make some minor changes to the fuel line and the linkage.
~John
71 Blazer One Ton
59 Belair 2 Door
Old 11-09-2006, 08:40 PM   #9
corn
I love everything Edelbrock makes. Except their carbs. I like Holleys myself, never heard anything bad about a Demon...
corn is offline   Reply With Quote
Old 11-09-2006, 09:07 PM   #10
70c10
67-72 Addict!
70c10's Avatar
I have the 625 Road Demon and love it!. I had the Edelbrock on it before and there is no comparison performance wise, even though it was reliable. I had a well known racer tune my Demon and timing -WOW what a difference he made!.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 11-09-2006, 09:18 PM   #11
Rick Mills
Rick Mills's Avatar
I had a 625 Road Demon (Vac. secondary) on my 454. I love it. I use a bigger Holley double pumper for performance only. When I'm just driving around town I use my Road Demon. On weekends or special shows I put on the Holley 800. I did have to re-jet both carbs for my elevation. The Road Demon idles smoother, the Holley has more neck jerking response. For jetting info, check out the Mortec web site.
The Fastor Pastor
'68 swb, 447 BBC/ 6-71 Weiand, Dual 950 Bigs Carbs/ 2 1/2" Header tubes - 4" collectors/ M-21 4speed:
'70 swb; TH-400 - bagged & shaved. Looking for new engine or parts.
Wife - Original {A Real Classic!}
Rick Mills is offline   Reply With Quote
Old 11-09-2006, 10:21 PM   #12
71chevylowrider
Hey thatnks you guys, I appreciate your insite, man 70C10 you seem to always have the info I need, I need to buy you a Beer or 2, I think I might just try it, nothing like testing before buying right? I'm no carb tuner so it's getting old having to have someone dink with it, I want to get it dialed in go drive around & enjoy it, hopefully the rain will let up so I can do some test driving over the weekend.
Old 11-09-2006, 10:46 PM   #13
70c10
67-72 Addict!
70c10's Avatar
Don't feel bad, I'm not a carb tuner either,lol. I started my truck yesterday for the first time in 3 months and it fired right up!. When I went with the Demon I bumped my initial timing up to 19 degrees and the total is 42 degrees. Of course that was with my old harmonic balancer. I never checked it with the new balancer to see if that's correct.
Jim
Old 11-09-2006, 11:05 PM   #14
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
I want a Demon, they seem like they are nice parts
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 11-10-2006, 02:58 AM   #15
Machu10
Junior Member
Machu10's Avatar
I have a Speed Demon 750on my 383, I love it, once it was set she purred like kitten.
72 Cheyenne Super ShortBox, Factory Big Block, A/C PS PB.
71 Cheyenne LWB, 350, A/C, 48k Miles
70 Olds Cutlass Convert, A/C, 350 auto, 66k actual miles.
82 Corvette, Triple Black, 32k Miles, Had since new.
85 Caprice Coupe, Bottle fed 383 Stroker, 30k miles.
06 Dodge Charger Daytona, Top Banana Hemi.
Machu10 is offline   Reply With Quote
Old 11-10-2006, 12:52 PM   #16
JameslovesJammie
God Bless Mr. T
JameslovesJammie's Avatar
If you go Demon...get the Road Demon, NOT the Road Demon Jr. I have heard nightmares about them not staying tuned at all.
Like a midget at a urinal...sometimes you must stay on your toes.
JameslovesJammie is offline   Reply With Quote
Old 11-10-2006, 01:58 PM   #17
70c10
67-72 Addict!
70c10's Avatar
I have also heard this about the Jr. version.
Jim
Old 11-10-2006, 02:05 PM   #18
bryanw1968
bryanw1968's Avatar
Go with the demon. I've had 3 of them on different applications and love em'.
The construction alone of a demon is reason enough to buy it. Billet base plate, billet metering blocks, screw in air bleeds, 4 corner idle adjustment and sight bowls for beginners. Holley's and Edelbrock carbs are also good but the quality just isn't there. The demon carb is precision machined and drilled, not sand cast like the ones mentioned above. Meaning, even if the demon is used, there aren't any holes with burrs to dirt and goo to hang onto.
I have a 650 speed demon mechanical secondary and once dialed it in I haven't touched it in over 2 years.
bryanw1968 is offline   Reply With Quote
Old 11-12-2006, 08:15 PM   #19
71chevylowrider
I got it last night, cleaned it up a bit with Carb Cleaner, These things are built like a tank! I love it so far, is ther anything I should do/change before I bolt it on? I know it ran fine other then the old guy said that he didn't like the way it Idled, but...what does that mean? His motor was mostly stock other then headers, so I don't want to change much till I try it, where's a good place to get info/parts kits for these Road Demons? Oh this one has Vacume secondaries, not sure what my 1406 was.
Old 11-13-2006, 12:34 AM   #20
70c10
67-72 Addict!
70c10's Avatar
http://www.barrygrant.com/demon/default.aspx
Jim
Old 11-13-2006, 12:58 AM   #21
Slammed70
Slammed70's Avatar
My father...and a buddy of mine both run Demons, and they've both had the same problems.
My dad bought his because its shiny and looks good sitting between his stainless fenders/firewall on top of his polished 427 side oiller. And my buddy bolted one up to a stock, worn out 350 in his mid-80s truck.
Both had the same problem....the idle circuit went out. They ran good off idle and were just mean at WOT.
I know someone said it earlier....but I have to reiterate. They arent street friendly, they were designed for and used primarily for racing.
Just a side note...my truck had a Carter 4bbrl on it the day I brought it home. Less then a week later I had on an Edelbrock....Ha, I threw back on the Carter until I had the money to upgrade. I was working at Autozone at the time and I bought me a brand new Holley Street Avenger. I went way to big for my tired 327....770CFM, but it was all we had in stock. So here I am a year and a half later and I love it...it was set dead on out of the box. The only problem was I couldnt fit my air filter over the bowls, but a 1/2in spacer fixed that right up.
Slammed70 is offline   Reply With Quote
Old 11-13-2006, 04:13 AM   #22
brak
brak's Avatar
... I have a performer RPM manifold, I read on Edelbrocks website that they don't recommend the 1406 on an RPM manifold, maybe that's my problem? I didn't get whay they don't recommend it.
I skimmed through the replies, and didn't see this addressed.
The 1406 is a 600cfm carb, which works great with a performer manifold, but the
RPM manifolds are larger, require a 750cfm carb.
That carb is too small, so you could either swap for a larger carb (ie edelbrock 1411), or step down to a smaller manifold.
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 11-13-2006, 12:51 PM   #23
71chevylowrider
Idle circuit went out? What does that mean? Is this a replaceable part?
I thought a 750cfm was too big for a small block? Even with the RPM manifold.
Old 11-13-2006, 01:12 PM   #24
panhandler62
Java Mechanic
panhandler62's Avatar
There really is no "too big" .. well.. not in so many words anyway.
The correct match between the carb, manifold, and the ability of the engine to move air is what matters. Setups that work maintain acceptible vacume and velocity through the opperating range.
Lower flow units mantain better idle vacume but give up top end flow. Higher flow units provide the needs at top end but sometimes are pissers at idle because the vacume falls off to sharply. Things like vacume secondaries and the spreadbore arrangement that q-jets (and other) carbs have are used to compensate on street cars... providing idle vacume and top end flow.
A 350 can easily flow 750cfm but will probably bog off idle with that size carb with a stock drivetrain. (less of a problem for autos than manuals ...)
When you mismatch a carb and manifold you really can't find the sweetspot because there is no (or a very narrow) range in which the flow and vacume characteristics of the two parts complement each other. Cam choices matter here also, but not so much in the normal "off the shelf" parts on near stock setups.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 11-13-2006, 01:26 PM   #25
71chevylowrider
Unfortunatley I can't get the previous owner to remember what Cam was installed in the Motor, it is a very bumpy roller type, but He can't remember much, he think's it might be an isky, but not sure. After looking at Barry Grants site, i wish I was installing a Street Demon now, it sounds like it's more for a modified engine like mine & the Road Demon is more for a stock motor. But I'm still excited to try a better carb then the edelbrock 1406 I was using,
slammed70, is there a chance that the Demons you & your dad had were Road Demon jr's? Those are the only ones I hear bad things about.
