Where's my beer?
Cleaning up very rusty frame, what to use?
I have a very rusty frame, in some places the rust is flaking off, what do you guys use to clean it up? I can't afford sandblasting it
![]() TIA ![]()
Paul How do you make the invisible, visible?.........You take it away. Last edited by chevy_fatman; 11-09-2006 at 11:25 PM. |
Re: Cleaning up very rusty frame, what to use?
where are you located?? are you near chicago I sandblast water towers for a living and am currently laid off for the winter. I could blast it for you very cheap.
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
Where's my beer?
I'm in PA, thanks for the offer but that's a bit far for me to drive
Paul How do you make the invisible, visible?.........You take it away. |
Not a prob, just figured that I would put the offer out there. Doing a frame would take no time at all. Jon
its all about the +6 inches
Paul an angle grinder and wire wheel would probably do OK. However, I wouldn't just prime it. If you dilute a quart of rustolium, a little thicker than 50/50, it'll cover the whole frome in a couple coats, and be way better than primer.
Oilfield Trash
Any non-criminal sandblast shop should be able to blast and paint it for 300 bucks, and have it ready the next day, thats what i did for the 72, but the 71 he blasted right through the rear frame rail, after i shortened the frame of course.doh!
14 Dodge 3500 Mega Cab 08 Dodge 3500 Mega Cab 87 Chev 3+3 4x4 80 GMC K10 High Sierra bone stock 70 Chevelle 350SS long term project 68 GMC 3ton Grain Truck/Garbage wagon 50 Pontiac 2 Door Coupe Project "I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr. Last edited by Blue85; 11-10-2006 at 01:12 AM. |
Where's my beer?
Andy thanks for the advise, I really haven't looked around (locally) and see if I can find rustolium, I need this done this weekend as is going to be nice to work outside and I'm under a time crunch and no garage, I'll run to tractor supply store and my local PPG store and see what I find.
I did a search and restolium is what a lotta peeps here use in the board, Thanks ![]() edit: Blue85 I'm trying to get it done for the cheap, $300 is more that I wanna spend on this, Thanks for the suggestion ![]()
Paul How do you make the invisible, visible?.........You take it away. Last edited by chevy_fatman; 11-10-2006 at 01:17 AM. |
Sinister Exaggerator
If you are near a home depot or similar store they usually have rustoleum in quarts and gallons. the stuff is pretty hard to beat.
69 c10 Chevy Long Fleet 350/350 *under construction* Poor man's disc brake upgrade with HydroBoost from '82 diesel Blazer tank with "John Fabris" stake pocket filler (Genius!) |
Paul, try the tractor paint sold in Tractor Supply. It is cheap ($20. gal) and it seems to cover and protect a whole lot better then it should given it's price. It comes in all the cool colors--John Deer Green, Intl Yellow, Kubota Orange--etc. but it is also in Black, Silver, etc. Use a heavy wire wheel on a grinder but be sure to wear protective glasses. If the metal is still think enough to be safe, this paint will protect if long enough ----for sure!! Huck
I wire wheeled everything from the cab back, including removing the diff and filed down any sharp spots. When it was all shiny, I clean the whole thing with lacquer thinner - then sprayed two coats of rust restore on everything - that took care of any tiny pits I might have missed. Then I primed two coats and then two top coats - came out very pretty - but it took about 30 hours (not counting paint drying time) - and that was just from the cab back. If you put time into it, make it count.... I'd hate to have to go back and do it over!
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
NCStroker
looks really good! nice job!
1971 Chevy C/10-Built 383 Stroker ![]() |
![]() Join Date: May 2006
try wal-mart, ours has rustoleum. it's around 9 dollars a qt
#13 |
Post Whore
I would still check locally on sandblasting, mine was alot cheaper than $300, I got the frame blasted AND powdercoated for $250 but I think most places are a little higher than that. If you have a place around you that makes tombstones they will normally sandblast things for around $30 an hour
Drew '71 Chevy 350/TH350 Hugger Orange Currently just a rolling frame, body work soon to follow!!! Check out my Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=212927 Daily Driver: 1997 Chevrolet S-10 with more gears than pistons ![]() |
#14 | |||
Union Electrician
I used a poly carbonate wheel that is made for rust removal, got them at harbor frieght and worked like a dream. I used about 15@ $4 a piece and took the entire frame down to bare clean metal by myself in about a days work. Ther are not as agressive as a grinding discs and MUCH MUCH faster than the wire brushes. With the estwoods kit I bought for my frame and all the poly wheels I have about $175 total in mine and it looks great IMO..
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
