Old 11-10-2006, 12:29 AM   #1
QKENUF4U
QKENUF4U's Avatar
Question where do you put the jack stands......
next couple weeks im gonna be swapping my 3:08 rear with a guy who has a 4:10 rear. do you guys use the big huge jackstands under the frame or what ?
thanks
lance
QKENUF4U is offline   Reply With Quote
Old 11-10-2006, 12:40 AM   #2
BarryB
BarryB's Avatar
Re: where do you put the jack stands......
Jack stands under the frame but have truck high enough to drop rearend out, and put smaller jack stands under the trailing arms, It is coil spring???
BarryB is offline   Reply With Quote
Old 11-10-2006, 12:57 AM   #3
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
that or lift it with an engine hoist.
trkklr77 is offline   Reply With Quote
Old 11-10-2006, 09:16 AM   #4
QKENUF4U
QKENUF4U's Avatar
trailing arm suspension
no engine hoist
Old 11-10-2006, 10:02 AM   #5
cdowns
cdowns's Avatar
i put up the frame rails on stands// i let the brake drums on a couple of pieces of 2X6 then just let the trailing arms fall to ground when i cut the ubolts// while your at it it's a great time to change the trailing arm bushings and the panhard bar bushings
Old 11-10-2006, 01:48 PM   #6
arkracing
Weekend Warrior
I would leave the rear tires on it so that you can roll the rear end right out the back after unbolting everything.
Put the jackstands infront of the rear end though
You can almost put the up towards the trailing arm crossmemeber on the flat part of the chassis and not have to worry about the stability - but always shake it before getting under it!!!
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 11-10-2006, 05:36 PM   #7
6T8
Active Member
I leave wheels off you don't have to jack up as high. Set floor jack under punkin and roll out. Just my 2 cents........Rick
6T8 is offline   Reply With Quote
