Old 11-10-2006, 01:40 AM   #1
prostreet1967
prostreet1967's Avatar
under bed battery relocation
any one have pics of under bed battery relocation
prostreet1967 is offline   Reply With Quote
Old 11-10-2006, 01:53 AM   #2
ghetto_superman
ghetto_superman's Avatar
Re: under bed battery relocation
ditto.
ghetto_superman is offline   Reply With Quote
Old 11-15-2006, 08:54 AM   #3
prostreet1967
no one here done this before
Old 11-15-2006, 04:41 PM   #4
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
I put two either side of my ram and used heavy welding lead wire up the frame to the starter.If yours doesnt tilt you could make a box to mount to the frame.
sneakysnake is offline   Reply With Quote
Old 11-15-2006, 04:49 PM   #5
Toms Truckin
Toms Truckin's Avatar
I was just curious, does this require alot of time getting access to the batteries? Seems like a great idea, if they were still easily accessible.
72 GMC Sierra Grande
Toms Truckin is offline   Reply With Quote
Old 11-15-2006, 04:50 PM   #6
sneakysnake
A little Google came up with this.Mounted to the frame would work.
http://www.robinson-race-cars.co.uk/Battery%20boxes.htm
Old 11-15-2006, 04:57 PM   #7
ghetto_superman
i dont remember where it was.. maybe summitracing somewhere.. but i think theres a box that somehow flips down so you can get better access to it. that would probably be what i would go with.
-1947 3100 -1968 C10 -1970 K20
Old 11-15-2006, 08:17 PM   #8
71STPSDE
71STPSDE's Avatar
Here is a picture of my battery under the bed.
Of course I can raise my bed. The PO removed the wood bed and put plywood covered with astro turf. I'll change it back to wood someday, but I'll have to redo the battery and fuel cell.
71 Chevy Stepside
377/350
71STPSDE is offline   Reply With Quote
Old 11-15-2006, 09:52 PM   #9
Fastfun
Fastfun's Avatar
Here is a relocated battery box from CPP
http://www.classicperform.com/tech_a...attery-Box.htm
Check it out
Fastfun is offline   Reply With Quote
Old 11-15-2006, 09:57 PM   #10
BowTieMan
BowTieMan's Avatar
Not mine
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo
BowTieMan is offline   Reply With Quote
Old 11-15-2006, 11:11 PM   #11
kwmech
The diesel chevy vans have a frame mount under the---- drivers side? May be avail in the PnPs
Old 11-16-2006, 02:25 AM   #12
ghetto_superman
that CPP box looks pretty cool... do you think the hooks would come undone on a big bump and the box falls off the tracks tho?
Old 11-16-2006, 02:33 AM   #13
Kenneth_CS87
Attachment 225031
What size fuel cell is that? Are you running a external pump for it?
Kenneth_CS87 is offline   Reply With Quote
Old 11-16-2006, 03:07 PM   #14
71STPSDE
71STPSDE's Avatar
It is a 16 gallon fuel cell. And yes it has a external fuel pump.
71 Chevy Stepside
377/350
Old 11-16-2006, 03:55 PM   #15
pat
pat's Avatar
Heres mine
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s
64 Cadillac Sedan DeVille
pat is offline   Reply With Quote
Old 11-16-2006, 04:08 PM   #16
prostreet1967
Originally Posted by pat View Post
Heres mine
GOT ANY OTHER PICS OF YOURS WITH BATTERY OUT I LIKE THAT SPOT
Old 11-16-2006, 08:30 PM   #17
pat
pat's Avatar
Sorry, thats the only pic I have. The backside looks just like the front side, except with some tabs on the side to bolt it to the frame. I just made it with some small angle iron, C-channel, and threaded rod.
Old 11-16-2006, 10:36 PM   #18
Deuce
Deuce's Avatar
Heres the one I built.The battery is mounted with 1/4" bolts through the plastic base of the battery in the flat spot between the cells. The battery is bolted in in this pic.
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 11-17-2006, 08:14 AM   #19
prostreet1967
did u make the battery tray and frame mount or buy it? very nice
