Old 11-10-2006, 01:59 AM   #1
skokie
skokie's Avatar
Throttle rod and plug wires
I am looking for ideas here on how to solve this little problem I made for myself when I dropped in my HEI. If I hit the gas the throttle rod hits the plug wires for #s 5 and 7. Any ideas on how to move these out of the way?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 11-10-2006, 02:18 AM   #2
Bad71chev406sbc
Bad71chev406sbc's Avatar
Re: Throttle rod and plug wires
How about either making a new throttle rod, or modifying it. Making it bend our father away from the carb, and farther away from the wires.
'71 SNB, 406sbc, TH350 w/ Transpak & Starshifter, 12bolt w/ 3.73s, 2" Early Classic front coils, 2.5" Flowmaster Super 40's
Bad71chev406sbc is offline   Reply With Quote
Old 11-10-2006, 07:43 AM   #3
Jim_PA
Can't you get swome more slack in the wires, so they will just lay down a little more?
Jim_PA is offline   Reply With Quote
Old 11-10-2006, 09:25 AM   #4
brak
brak's Avatar
I would recommend a good set of wire looms such as "made for you" since they have a seperator block that you install near the distributor to effectively flatten the wires, making routing easy. I bought a set a couple years ago, and will never buy anything else. they're installed on all my vehicles.
also i would suggest getting a set of universal wires (brand of your choice), so you can cut them to the exact lenght you will need to clear any obstructions.
Made for you website
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 11-10-2006, 11:14 AM   #5
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Could you just use a holder like this to keep them together and out of your way
sneakysnake is offline   Reply With Quote
Old 11-10-2006, 05:32 PM   #6
skokie
skokie's Avatar
I tried that but they wires wont stay down. HMMM I wonder if one of those wire looms that bolt to the valve cover bolt would work if I bent it and put it on the last intake bolt on the drivers side.
68 build thread
Old 11-10-2006, 11:31 PM   #7
Slammed70
Slammed70's Avatar
Ewwwww.....a Q-jet.
Lol, sorry....I had the same problem. I took off the factory 2brrl, intake, and factory distributor and threw them all in the street. Then I did the HEI, Holley Street Avenger, and Weiand intake(now an Edelbrock Performer RPM).
Bein a 70 I got that ugly linkage style throttle too, I had to bend mine up to get past the high rise intake, then the PEDAL up the I could get full travel on the carb. I dont recall havin any problems with the plug wires though.....compared to mine and my buddies, your looks flatter then ours. Has it ever been bent before?
Slammed70 is offline   Reply With Quote
Old 11-11-2006, 02:07 AM   #8
skokie
skokie's Avatar
I like the qjet comment I got that throttle rod when I got the carb which came off of a 68 3/4 ton 327. As far as I know it has never been bent. My truck originally had a 307 in it and I believe I have the rod for that but will have to go look.
68 build thread
Old 11-11-2006, 02:51 AM   #9
skokie
skokie's Avatar
Ok I dug up the old rod. It is 14 inches long. The one that came with the qjet is 16 inches long. Also if you look at the pic you will see on the longer one there is a flange on it that is not on the shorter one. I also noticed something tonight. If I put that flange piece toward the back where the pedal assembly goes then it clears the wires. However the piece that I have to put it in place wont work cause of that flange Figures. So here is the question. How is a qjet throttle rod supposed to be hooked up? Which end goes where?
68 build thread
Old 11-11-2006, 04:12 AM   #10
OhioDan
OhioDan's Avatar
The adjustable end should go to the front, to make adjusting the length easier. Also, so nothing sticks out the back to hit firewall. Just my $.02.
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 11-11-2006, 08:38 AM   #11
timcos
Chief Honcho In Charge
timcos's Avatar
What is a "made for you" ?
Thanks,
1992 1500 4x4 Shortbed
1984 Ford F250 Supercab Longbed 6.9L Diesel
1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
1967 C10 SWB (1980-1981)
1971 C10 LWB (1998-2004)
timcos is offline   Reply With Quote
Old 11-11-2006, 11:49 AM   #12
Rdrdave
Broke and still trying
Rdrdave's Avatar
I made my rod from threaded rod and some female heim joints. I then covered the threaded rod with some aluminum tubing and presto, looks like a solid high end throttle rod without the cost. All materials from your local hardware store.
Rdrdave is offline   Reply With Quote
