11-10-2006, 03:40 PM | #1 |
how to put the hood back on by yourself
the only way that i can think of doing it is to use a cherry picker. any other ideas?
11-10-2006, 03:45 PM | #2 |
Re: how to put the hood back on by yourself
thats the way i've always done it a couple of blankets on the fenders hook the hoist by the latch and walk it into place // WORKS GOOD
11-10-2006, 03:51 PM | #3 |
grow more arms maybe? I took one off by myself...
If you have your brackets mounted and in the up position then you might have a shot, but plan on scratching things. I have sat mine on the truck by myself but haven't mounted it yet. I'm also 6'3 and a big guy and it nearly whipped me. |
11-10-2006, 05:31 PM | #4 |
Active Member
I've done it myself used broom handle to hold up. Scratched alot of paint. Cussed a little. Next time I bought 6 pack and invited neighbor over. Whipped me and I'm 5'7" and stocky. Silverback type
11-10-2006, 05:48 PM | #5 |
its all about the +6 inches
I've always used a broom stick and did it myself, never a scratch. Throw a blanket or your jacket or something at the bottom of the hood on the cowl, lift it up and over, prop it up with the broom stick, then carefully bolt it, lower while loose, slowly try co close it, and line it all up.
11-10-2006, 06:19 PM | #6 |
I do it the same way Longhorn Man does.I have 5 boys but always wind up doing it by myself.Seems I can never find the boys when I need them.
77 swb starting all over again. |
11-10-2006, 06:35 PM | #7 |
im 5' 11" 175lbs i did it for the first time with no stratch anything (the paint is CHITY!) the only problem i had was figuring out a way to tie the rope so it would stay when it was up in the air and being moved around. i think im going to make a.... for lack of better words a tool like a capital H with 4 magnets that have a rubber coat over them so i wont scratch anything when i get her all painted up. it does have surface rust in quite a lot of places but only one place on the lip over the windshield on the passanger side has cancer and from what i can tell it is going to be an easy fix.
11-10-2006, 08:54 PM | #8 |
i've used a block and tackle with some clips and just suspended it above and drove the truck under it
11-11-2006, 01:02 AM | #9 |
That's pretty funny , i'd rather try any of those methods than have to ask my red-headed wife for help .
Can-Am Motorsports 37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser . 64 Biscayne 409 2x4 4 speed 4.11 posi 65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon) 68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD) |
11-11-2006, 03:09 AM | #10 |
Ok here is the way I have done it. 1 remove inner fenders. 2 remove all but 1 bolt from each hood hinge where they atach to the fender. 3 move the hinges down to where they are paralle to the fender. 4 cover fenders with heavy blankets to keep from scratching. 5 lay hood on hinges. 6 put bolts in one hinge to hood bracket. 7 put bolts in other hinge bracket to hood. 8 lift hood to where holes in hinge to fender line up. 9 use 2x4, broom handle or whatever you want to hold up hood. 10 install remaing bolts to hinge to finder. 11 have fun adjusting the hood to fit. This is the easiest way I have found to do it by myself.
Aaron |
11-11-2006, 06:47 PM | #11 |
If I can pick the hood up by myself I can put it on by myself. I have been in the body shop business for over 25 years and there was a lot of times I was working alone. I love these new sh@@ box Hondas and Nissans I can flip one of those hoods like a Frisbee. Now a hood off a '72 Buick Riviera man that's a killer. I do like like Longhorn Man I use a broom stick blankets down both fenders and around the cowl area and take my time.
'07 G6 Wife's car '00 Malibu stock, just a parts getter. '99 Blazer LT Loaded, K&N Filter, Pioneer Super Tuner,Viper '88 K1500 Cheyenne, 5.0, stock, bought new '86 Nissan 720 Trash Truck '69 C/10 step side, 307, all original, second owner, in process of restore. The person who says it cannot be done should not interrurt the person doing it. Share your knowledge. It is a way to achieve immortality. Allen- Paintman Wrenchtwister Broompusher |
11-11-2006, 06:59 PM | #12 |
67-72 parts finder
i drug my whole front cap off and put the other one off by myself hood and all not that hard just gotta be determined
1969 chevy shortstep 2wd (under construction) 1981 chevy scottsdale lwb 2wd (parts chaser) 2004 pontiac gto (daily driver) 2004 pontiac grand prix gt (the ol ladys car) 1985 chevy short wide 1970 chevy c10 lwb (another parts rig) 1969 gmc lwb (rainy day project) 1968 chevy lwb c10 250 I6 3 spd (soon to be swb) |
