computer illiterate
pertronix or hei?
are the pertronix units anywhere near close as efficient and reliable as an hei? the reason i am asking is because i have a 70 3/4 ton 4x4 im building. and i bought an hei for it so i could do away with the points, but it looks like it will be a real tight fit with the firewall. so i was thinking of maybe running a pertronix unit. if the pertronix are good the does anyone have a kit layin around to sell or maybe have a part number for the one i need?
72 2wd blazer 72 swb 4x4 |
Re: pertronix or hei?
MSD Is a better choice...... Petronix is reported by many to be not so good!!!
Last edited by wolfthing2000; 11-10-2006 at 05:32 PM. Reason: Not clear as to what I mean. |
computer illiterate
got a part number?
in craigslist /orlando there a complete new pertronix billet hei dizzy setup cheap
its all about the +6 inches
you can get parts for an HEI at any parts house from sea to sea.
computer illiterate
i didnt ask for hei parts i wanted to know if the hei i bought would clear in a stock k 20 or if i would be better off going with a pertronix unit. and if a pertronix if someone had a kit for sale to convert my points dizzy
Active Member
i have issues with it being a little close to the firewall, just makes the cap a little hard to get off. how about looking at one of the remote mount coil setups, with the directional wire caps?
OK.. I read it as which one would be better... a conversion, or HEI...
My opinion is, HEI, the main reason is that you can get parts anywhere any day and not have to special order anything. If you turn it in the right direction, it'll clear with a little room to spere. You can slide the engine forward almost a 1/2 inch with no mods if need be. |
the petronix dizzy setup is the same size as the points dizzy no clearance problems
My Mallorey HEI does everything but touch my firewall with an Edelbrock intake. Close but it works, I have a K-10 with 327 SBC in it. I also looked into the Crane conversion ($70) but went with the whole new HEI instead.
I had the Pertronix conversion kit in a 68 Impala. Drove it off and on for a couple years with no problems.
WTB this ad
I have HEI on my K10 and have ran it in a K20. It's a tight fit, but it will work. I have also ran Pertronix. I didn't really care for the ignitor because it had a delay of a couple seconds before it would activate. The ignitorII doesn't use the delay.
#13 |
![]() Join Date: Jul 2004
New cab mounts help with HEI clearance too. Usually the front mounts use the mounts plus an additional 1/8 thick square washer on top. Every little bit helps.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
#14 |
Just go MSD and forget the rest!!!!
#15 |
I had the pertronix dizzy with the Ignitor II in it. Worked for about 14-15 months then I noticed it was hard to start. I put in a HEI and my truck has never started so fast in its life.
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
#16 |
hei's in both my k10m and k 20 with room to remove cap and ajust timing
common sense isn't so common anymore |
#17 |
Msd
#18 |
aftermarket should make a vaccum advance remote coil HEI
#19 | |
The P/N I installed was Summit PNX-1181. I really like the unit, it was a quick install and I get to use the standard cap, etc. |
#20 |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
I have a 74 corvette and the tachometer drives off a cable from the distributer so I wanted to keep the distributor but ditch the points. I talked to every street rodder and muscle car guy I could find who had changed to the pertronix units and nobody had anything bad to say about them. I bought the pertronix II but have not installed it yet. I'm concentrating on the truck which has the HEI conversion. I think that if I had the choice I would go with the HEI units, but those small Distributor caps look pretty slick.IMO
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
#21 |
VetteVet This is what I used to run http://store.summitracing.com/partde...5&autoview=sku
Replaced it with HEI.
#22 |
pertronix makes a vaccume advance dizzy HEI with remote coil// summit jegs speedway all sell it
#23 |
There is/was also a Mallory pointless kit also................don't know much bout it tho.
